-   -   Power Window Experts Needed (http://forums.pelicanparts.com/porsche-911-technical-forum/484018-power-window-experts-needed.html)
speedman 07-07-2009 08:53 AM
How hard is it to remove the driver side power unit
KevinP73 07-07-2009 09:25 AM
On a scale of 1-10 I'd give it a 7.
speedman 07-07-2009 09:27 AM
Can the gears be replaced in the gearbox or do you need to replace the entire unit
KevinP73 07-07-2009 09:42 AM
Replace the whole unit
speedman 07-07-2009 09:44 AM
The power window switch will only make the window go down. If I swap the green and black wire the window will go back up. The switch is brand new also
KevinP73 07-07-2009 09:48 AM
Sounds more like the switch is wired wrong. Run a search and you'll find several diagrams with the correct plug sequence.
crustychief 07-07-2009 10:48 AM
http://forums.pelicanparts.com/showthread.php?t=288567&highlight=window+wiring+di agram
Did it for you.
rick-l 07-07-2009 11:07 AM
Sounds like the bad switch is in the drivers door.
That is if it is the passenger window
Mysterytrain 07-07-2009 11:40 AM
The new switches are crap. Check the wiring if the you can hot wire it and make the window go up and down I would get another switch.
