speedman's Avatar
Power Window Experts Needed
How hard is it to remove the driver side power unit
Rick T
Old 07-07-2009, 08:53 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
On a scale of 1-10 I'd give it a 7.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 07-07-2009, 09:25 AM
speedman's Avatar
Can the gears be replaced in the gearbox or do you need to replace the entire unit
Rick T
Old 07-07-2009, 09:27 AM
1.367m later
KevinP73's Avatar
Replace the whole unit
Old 07-07-2009, 09:42 AM
speedman's Avatar
The power window switch will only make the window go down. If I swap the green and black wire the window will go back up. The switch is brand new also
Rick T
Old 07-07-2009, 09:44 AM
1.367m later
KevinP73's Avatar
Sounds more like the switch is wired wrong. Run a search and you'll find several diagrams with the correct plug sequence.
Old 07-07-2009, 09:48 AM
crustychief's Avatar
Power Window Switch schematic
Did it for you.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 07-07-2009, 10:48 AM
Sounds like the bad switch is in the drivers door.
That is if it is the passenger window
Rick
88 Cab
Old 07-07-2009, 11:07 AM
The new switches are crap. Check the wiring if the you can hot wire it and make the window go up and down I would get another switch.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 07-07-2009, 11:40 AM
