What to top up Tranny with
I had a small leak in my axle seal that I fixed last night and I know that I lost a little Swepco from the tranny.
It has about 1600Miles on the Fluid. I don't want to order a Gallon and pay to ship it tpo Canada until fall when I changew the fluid. What can I put in for now. I probably only need a half a liter to top it up. Something I can buy in Canada Please.
JOHN 79 EURO SC "24 Years Later - The Dream Came True" |
RETIRED
P-car Shops order it by the drum.....don't you have one local you can go buy a pint/liter from?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
abides.
I can't comment on tranny fluid compatibility. I would find someone nearby with a leftover quart of Swepco. I have no doubt that there are many 3/4 empty, 1-gallon bottles of Swepco 201 out there in the deep dark recesses of our garages.
Graham 1984 Carrera Targa |
if you plan to service in the fall just order a gallon now , top up , seal the lid tight (so you don't spill it) , put it on a shelf and the in october take it down and service tranny accordingly
Administrator
How much do you think you lost?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Don't top it off, or you will blow your main shaft seal, as the oil seeks a way out of confinement. What's the transmission? I believe the rule on the 915 was keep it 1/2 ( or was it one) inch below the fill hole. As Jack Olsen asked, how much did you loose? Fixing something that's not really broken can be a costly experiment...
John Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers |
Slumlord
Caution: Foreign Content.
I would top it up with Canadian Tire 75/90 cheap crap. I can't see it hurting at all.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
John
I have some left over from a fill - Port Moody call me 469-0281
Carl Selden 64 356 C + 73.5 Targa -, 73.5 911 Targa - 65 356 C -,63 356 B - 75 911S Targa - |
Other option Syncro shift 2
I used a product from BG called syncro shift2 on my last tranny fluid change and it comes in litres. I found it actually worked slightly better than the sweptco in my 915.
Doug 97 C2S 993(last one) 95 993 cab- 85 911 M491 87 944 Turbo- 70 914-6 63 911 |
