oil pressure pinned
Howdie y'all
Ever since I rebuilt my 2.7 my oil pressure guage has been pinned at 140, when ignition is on, engine running or not. Has any one had this problem? Any suggestions? Thanks Cooler |
Bad ground/wiring issue. I'd fix it fast if you're breaking in a rebuild...
Member 911 Anonymous
Check the wiring at the oil sender in the engine bay.
Mine was broken and after re-soldering it, she worked like new. To test, push the wire into the housing making a good contact, I bet it will work again then you will know what to do next. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Wer bremst verliert
Are you sure you didnt install the pressure switch where the sensor goes? I saw this once where the sensors were inadvertently switched.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
if the wire is removed from the sender or it is broken, the needle will peg
Doug
1971 RSR - interpretation |
