Wax on top of Carrera script???
I just re-installed my second set of Carrera script/decals (a BIG thanks to Mike Z for supplying the second set) and I am curious if you can wax over the top of the decal? Is this a no, no...a pain or simply something you should not do?
By the way, this time I installed the script/decal dry rather than using soapy water and the result came out much better. A few tiny bubbles here and there, but nothing compared the the amount of bubbles I ended up with when using the soapy water spray....for what its worth.
Old 07-10-2009, 08:10 PM
efhughes3's Avatar
You can wax over a decal.
I'm not sure why you had any problems applying decals with a tiny bit of soap (it is a very small amount) and water. That is the ONLY way I've ever had any luck. Actually, it takes luck to put decals on dry.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-10-2009, 08:21 PM
Recreational User
porschenut's Avatar
Originally Posted by efhughes3 View Post
Actually, it takes luck decals on dry.
What?
Old 07-10-2009, 08:39 PM
FASTLAP
porsche.racer's Avatar
I have never had a problem waxing my script... been on car for 3-4 years now with no problems...
1987 911 3.5L
1987 924S
2005 Audi A6 Quattro
2003 Cooper S
Old 07-10-2009, 09:22 PM
MikeD930's Avatar
I think Ed meant that once you place the decal on dry you can't move it around or remove it without "stretching" it. Whereas, using a little soap and water you have more forgiveness installing the decals.
Originally Posted by porschenut View Post
What?
MikeD '87 930
Old 07-11-2009, 08:37 AM
Zeke's Avatar
Pop the bubbles with a pin. Don't push into the paint in case you ever decide to remove the script.
Old 07-11-2009, 11:12 AM
Formerly known as Syzygy
Canada Kev's Avatar
I used to apply decals to vehicles professionally. We always did them dry. Ya just gotta do it the right way. Once its on, though, it's not coming off very well.
Kevin
Old 07-11-2009, 11:23 AM
Thank you all....I am not a pro and therefore not saying either way which way is the proper method of installing, but for me I did this 2 times. Once with a very light soapy water mixture and once dry and by far the dry method worked better as far as bubbles were concerned. You simply have to take great caution in making sure it is on straight and located where you want it because it certainly is not going to move around. Once down, its down.
Thanks, Craig
Old 07-11-2009, 12:18 PM
