??? This is a 2.4 with webers and custom made headers. Could it possibly be a broken head stud? I thought maybe an exhaust leak as it just started happening. I also noticed a gurgleing sound this afternoon after a drive. After I parked the car and turned it off I could hear the sound comming from what seemed to be the driver side of the motor.
Not likely a broken head stud. Gurgling at idle sounds like a header flange leak at the cylinder head to header joint. You probably burned out the gasket or have a broken exhaust stud.
------------------ Tyson Schmidt 72 911 Cabriolet 92 C-2 Cabriolet |
the gurgle sound was after I killed the engine, sound like the oil was boiling or somthing.really weird. I might add motor temp was about 200.
[This message has been edited by not_sure (edited 06-11-2001).] |
Senior Member
Best thing to do is jack it up and have a look. Inspect the exhaust area first. Then pull the lower valve cover and check the head studs.
I hope you only find a blown exhaust gasket. |
