gulkster's Avatar
83sc ROW calls for 98 octane...what to use?
What is everyone using in their ROW 3.0Ls? I recently read a post from Bill V. that says the 98 RON for ROWs was also to be leaded. I am using 91 (the best I have available) and a bottle of octane boost that treats 60L of fuel. Am I doing the best I can, or are there better ways out there. Do any of the additives in the octane boosts do anything for the valve guides (like lead does)?
edit: I just found an article that states that North American fuel uses the AKI system of octane, not the RON system. As such, it is claimed that 91 in North America is about 95 in Europe. I guess I'm doing alright then.
T-Shirt wearing, sticker toting, SCWDP registered member
Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it
'83 911sc ROW Targa
'84 BMW 320i (what did I get myself into?!)
Old 07-15-2009, 11:21 AM
Turbonut
Raceboy's Avatar
In Europe 98 octane means 93 octane in US. So use this and you (ok, the engine) will be fine.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 07-15-2009, 11:23 AM
gulkster's Avatar
you beat me to my own edit. lol I can't get 93 here...only 91.
'83 911sc ROW Targa
Old 07-15-2009, 11:26 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
FWIW, my '83 does just fine on 87 octane. Low compression engine, in comparison with more "modern" engines. How does the car run on 91 octane without the boost? You might just be burning money?
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 07-15-2009, 11:43 AM
gulkster's Avatar
I haven't tried without the boost. I probably am burning $s, but I bought a bunch of it on sale, so I'll use it until I run out. I do feel better when I'm screaming around a corner at 45' and 6500 rpm that I won't pre-detonate. I might detonate completely, but at least it won't happen before (much before) TDC
'83 911sc ROW Targa
Old 07-15-2009, 11:56 AM
Tim
Send a message via MSN to tvanbroekhoven
A ROW car should get 98 RON or 93 whatever you guys have in the States.
Otherwise you will get knock and that will make your engine sad.
More on 'knock': http://en.wikipedia.org/wiki/Engine_knocking
It is adviced to use a lead substitute at least every 3 tanks.
Long story short: get yourself an octane boosting lead substitute and you'll have an happy engine.
Just my 2 (euro-)cents
Old 07-15-2009, 11:58 AM
You should be O.K. running the highest test available but I would talk to your mechanic. It may be possible to slightly detune the engine (closer to US spec) to add some knock resistance.
I know less agressive timing and slightly over-rich mixtures can prevent knock. Of course the 83 CIS has lambda, so your adjustments with fuel may be limited.
Good news for you is up in Canada you temps are cooler. I know air cooled motors get very finiky as they approach their max operating temp (read almost overheat). Keeping the heads nice and cool is one of the reasons modern cars can run higher compression ratios with todays crappy gas.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 07-15-2009, 12:24 PM
gulkster's Avatar
Anyone know of a lead substitute available? Preferences? I am using some Valvoline octane boost for "racing applications", but it dies not say what it contains, or how much. Just tells to add one bottle per 60 Liters of fuel...
'83 911sc ROW Targa
Old 07-17-2009, 11:06 PM
