Help removing Chain Case
I am pulling my left chain case to replace leaking seals. I am fully dissambled and the case is loose. However, I am struggling to free up the thick cam Flange (w/ 3 bolts) that attaches to the head. I assume that the gasket is holding it tight, but I am not sure how to tap it loose. I am afraid to tap too much or too hard.
Can anyone give me some guidance or recommendation for freeing this flange?
Thanks in advance.
Larry
Old 07-20-2009, 10:44 AM
disregard. I finally found a place to tap it out from the back.
When I reassembe, should I leave the gasket dry? Do I do anything to the large o-ring, such as lubing it with oil, etc. ?
Thanks,
Larry
Old 07-20-2009, 12:50 PM
FWIW, I used some curil on the gasket as a sealant and a little engine oil on the oring to make it slip into position.
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 07-20-2009, 07:28 PM
