Santa Clarita, Ca.
Question Need a CIS wiring diagram
Ref; 77' 2.7CIS - Does anybody have a complete CIS wiring diagram that at least includes AAR, WUR, cold start injector, thermo sensor? The Bosch wiring diagram I have is incomplete. Possibly because it is for the earlier cis w/o AAR.
Old 07-18-2009, 12:11 PM
Santa Clarita, Ca.
Edit / Update - I found the wiring diagram shown below. Where is the "control relay" (#4) located on the car and what does it look like? (FYI - This 2.7 is in my 914 and was a "complete" and running engine when I bought it.) My cold start injector is not working and I have traced it to a wiring issue. I have everything in the diagram except the relay. When I search PP under "control relay" I get nothing.
Old 07-18-2009, 12:29 PM
al lkosmal's Avatar
That appears to be the fuel pump relay, typically the red one in your relay/fuse panel. Pelican lists it by this part number. 911-615-108-01-M58
Regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 07-18-2009, 04:15 PM
Jim Williams's Avatar
That is a generic CIS wiring diagram, and is not entirely accurate for your 77. The part about the cold start valve is right, but the fuel pump relay part is not. The relay wiring is different. Here is the fuel pump relay part of the diagram from the Factory Manual.
Hope this helps.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 07-18-2009, 07:10 PM
