just replacing my AC temp switch where does this tube..
in the process of replacing my AC temp switch and i found this brass tube in the evap housing . is this brass tube part of the old switch or should I put my new swich wire through it ?
It fits in our condenser coils and the capillary tube from the temp sensor in it.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
Just a small correction ... it goes in the evaporator.
You should have a white wire that inserts into the brass tube through a hole in the top of the evap box. coat the wire with grease before you insert it.
'85 RoW 911 Coupe '65 356 SC '72 BMW 2002Tii '10 Cayenne '20 Ram Longhorn |
