Prototipo - how to connect the horn?
Does anyone have a link on how to hook up the horn button on the Prototipo? Right now my horn is disconnected. (3,2 -84)
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Ferdinand Magazine
The button sits in a ring that sits between the wheel and the boss to give the horn button a decent earth connection. Then the horn wire attaches to the horn button and hey presto - it works.
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
zugelassener benutzer
I was sent a hub kit once without the horn ring, they sent me one ASAP after I called
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
"Then the horn wire attaches to the horn button and hey presto - it works." I wish it was that easy.
![]() When I removed the original wheel (three spoke) there was no wire still attached to the car and I'm 99,9% sure I didn't rip one off in the process. The only wire was the one behind the the actual "pad" on the wheel (connecting the pad to the wheel itself). I can't see a logical connection where one should be sitting in the exposed area left after removing the wheel. The Momo kit came with a loose wire so that is all dandy, but I need a pic or two where to connect it. What to do?
crappy photo but here it is
it could have been pulled out of the base. This is it installed. I look for install photos.
Ferdinand Magazine
You need to take the brass ring off the base of your Porsche wheel and fix it to the Momo boss.
Thank you for the help. Much appreciated!
