Trouble locating a new fan pulley nut
Okay, what the heck is going on here? Has no one ever cross-threaded a fan pulley nut? I cannot find a supplier for this nut! Today I managed to bugger up the threads on the 16mm by 1.00 pitch jam nut that holds the fan pulley in place. I have visited a hardware store, a fastener store, an auto parts store, called a Porsche dealer and an aftermarket Volkswagen Beetle specialty place as well as looked on Pelican, but I cannot find this simple little nut! Do any of you have a source?
Ordered mine from our host.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
16 mm x 1.0 Alternator nut........
Tony |
Band.
I got a 16 x1.00 nut from AAA metric in Denver:
http://www.aaametric.com/ They DO NOT have jam nuts, but they have regular depth nuts. So, it will work, but won't be 100% "proper."
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 07-20-2009 at 06:00 PM.. |
try pelicanparts.com new part search , alternator or give them a call i think they have an 800 number
Oh, an alternator pulley nut. That's the right terminology. Thank you for your replies. I ordered one from our host.
Band.
Where did you find it here on PP? Because I'd love to have the proper one, but everywhere I find it it shows up as $NLA. Unless 74-81 "Marchal alternator nut" will work.
Thanks!
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Go Speedracer, go!
Here's my story on that nut: Is there a way to repair the threads on the alternator shaft?
Long story short, the 16x1.00mm are NLA, while the later 17x1.5mm are readily available. I still have a spare alternator with repairable threads but I couldn't find a replacement nut for it. Good luck and let everyone know if you find a suitable (grade 8) replacement.
1981 SC ROW Coupe Last edited by SpeedracerIndy; 07-20-2009 at 08:30 PM.. |
Well that's interesting. I ordered part #928-603-904-00-M262 Marchal Alternator Nut. If you click "more info," it says "911SC / Turbo (1978-1983) (from 82)" Hmm...does this imply that the part is compatible with a 1978-81 car with an '82 or newer motor?
That nut is 17x1.5
Unfortunately you're right. Who knew that a puny nut would be so difficult to get?
Friend of Warren
Feel free to flame away, but when this happen to me I just rethreaded it to the closest SAE size which I believe was 15/16 (still have the die if you want to borrow it). Picked up the die at the local auto parts store. Worked just fine. Think it cost me around $10 for the die and 50 cents for the nut. If you want you can try and get a thread chaser and clean up the threads to see if you can get the metric nut to work.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I had two rebuilt alternators and each had a different sized nut. I took the alternator with a cross-threaded nut down to an alternator rebuilding place. The shop had a box full of old alternator nuts and they just gave one to me.
Rod |
Kurt V and Hotrod, those are both great ideas. I thought of the possibility of re-threading to a more standard size last night. Kurt V, do you recall the thread pitch for the imperial thread size?
Friend of Warren
I will try to remember to go home at lunch and dig out the die from the tool box. I know it was a fine thread.
Good news for me! I just located a source close to me that has four 16m-1.00 nuts! Thanks to Hotrod who inspired me to call a good alternator shop. |
Friend of Warren
If the price is right just buy all 4 of them!
I found M16 x 1.0 nuts at a local fastener outlet, after much searching. They had to be ordered in. Unfortunately the outside diameter is 24 mm not 22 mm so the alternator wrench does not fit. I am grinding down the flats to suit. They were not cheap, about $8 each. I bought a few, so if anyone needs one badly I can send one for about $10 incl mailing.
Carl Selden 64 356 C + 73.5 Targa -, 73.5 911 Targa - 65 356 C -,63 356 B - 75 911S Targa - |
I'm here to cause trouble
For this and a whole lot of other good metric fasteners, there is Mr. Metric in San Jose:
http://www.mrmetric.com/ JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
I bought 2 nuts at $4.50 each, and they are exactly like the original. They said that they continually stock the nut, so it is a great source for all who live in and out of the area. They are a well established auto electrical supply and service company in Sacramento. Here's their main website:
http://www.lehrauto.com/ |
