Testing 82SC CIS Lambda Brain
I have decided to hook up my O2 sensor and play with the stock set up to see what I can get for gas mileage. I have searched and invested many hours of reading and feel I have a good understanding of the CIS system. For background I have replaced all rubber relating to the system when I did the engine rebuild and do not have any vacuum leaks. I had my CO set to 3.5 at a local shop and car runs well OPEN LOOP and I do not have any issues but I just want to give the Lambda system a shot. I have tested system and control pressures and WUR is in spec.
My first impression with O2 plugged with CO still set 3.5 is a chugging effect with light throttle at constant speeds. This chugging is not bad and I have heard it described like pulling a trailer ( push pull thing.) One good thing is I do not have as much of a rich smell at idle because Lambda is pulling mixture lean at idle (? 45-50?).
As for testing I have a MAC EM710 digital volt meter that has both dwell and duty cycle settings. With all testing done with + at the green and white wire at test port and – grounded to engine I get 50% duty cycle with open loop I get 50% (normal). With car cold I do not get the 65% duty cycle but it is 80 degrees here so the cold start switch is not grounded because it is too hot. If I ground the wire for the switch I do get 65% cold start value. The only thing that has me scratching my head is if I ground the Lambda O2 wire I do not get 90% I get 70 or so. Because I do not get the 90% with Lambda wire grounded does this point to the brain? If it is the brain could this be the reason for chugging effect?
82 911SC
74 MGB
97 Land Rover Discovery
Old 07-20-2009, 05:49 PM
grateful user
don gilbert's Avatar
I think your going to have to put your co back to the original spec for lamda control, i tried it and got the same effects, maybe worse, lowerd it just enough for the 02 to keep at stoiche, ( d/meter should be bouncing around 40 to 60)and ran great.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 07-20-2009, 05:58 PM
Halm's Avatar
Originally Posted by don gilbert View Post
I think your going to have to put your co back to the original spec for lamda control...
Don, I thought 3.5 was the CO spec, no?
Thanks for any input here.
'17 Cayenne
Old 07-20-2009, 07:25 PM
grateful user
only if you've disconnected the lambda, put it down to 1.5 and try it there. if your frequency valve is getting a duty cycle from the ecm, it will correct to stoich at idle and part throttle.
Old 07-21-2009, 06:16 AM
Looking for duty cycle or dwell numbers how does one get to 1.5? As for now mine was set for 3.5 but has a duty cycle close to 50% closed loop. If I start to lean it out will the duty cycle change or would it stay around 50% until the 1.5 range and climb after that?
82 911SC
74 MGB
Old 07-21-2009, 07:34 AM
grateful user
my car and other 02 cars Ive adjusted runs their best when i adjust the co screw (as rich as possible) until 02 cant compensate any more, that way you will still have a stoiche idle and good fuel economy, and still have the mix rich when in open loop. this also makes advancing your timing to where it should be (32-36 max advance) a little more worry free.
Old 07-21-2009, 02:52 PM
I guess my big question is the surging at part throttle. Because mixture was set for 3.5 OPEN LOOP and now I'm in closed loop is the mixture too rich? I tested voltage at O2 and have .88 and from what I understand this is on the rich side. Even with this thing this rich I get the duty cycle of 49-51. What will happen to the duty cycle if I start to lean it out? I guess my question is does the mixture screw (not air bypass) have a direct effect on duty cycle?
82 911SC
74 MGB
Old 07-21-2009, 03:34 PM
grateful user
yes, your mix screw has an effect on duty cycle. if the mix is to lean, the duty cycle will go up, trying to relieve the pressure in the lower chambers of the fuel dist, which richen the mix, if to rich, the cycle will go down. also test your frequency valve by cracking the 35 degree throttle switch, duty cycle should go to around 90 for maximum wot enrichment. lot of variables for getting the correct mix on any certain car (atmospheric conditions, timing, engine mods) correct, are you sure yet that your lambda control is in good working condition? you can get a bosch 1 wire 02 at o'reilly part store for 20 bucks, and you must use the correct metal bosche relay under the seat, (another 20 bucks)those plastic 5 pin part store relays look the same but are not.
Old 07-22-2009, 06:00 AM
I have adjusted mixture slightly with duty cycle spot on 50% 2/3rds of the time with a slight tick up 51% and a slight tick down 48%. I went for a test drive and the slight chugging (push pull feeling) is much much better. My O2 sensor is new and working as far as I can test currently .78 on voltage with current mixture setting.
One major factor could be the relay. Mine went bad a year or so ago and I bought a black plastic one from Napa. The Napa relay has worked but I have had Lambda set for open loop and now that I want closed loop relay could be a factor. Lambda seems to work fine but I never can get 90% with grounding.
When I test the throttle switch it only will go to 65%
82 911SC
74 MGB
Old 07-22-2009, 07:03 AM
After some testing I have found that I get 65% with and without enrichment control box plugged in wile testing over 35% throttle.
82 911SC
74 MGB
Old 07-22-2009, 12:44 PM
grateful user
with engine running put your hand on the fre/valve to make sure it is buzzing, if not, clean the grounds under the seat good, check the main harness gang connector that is behind your heater blower motor, (the lambda has a separate harnesss from the main engine harnesss). unplug it and spay electro cleaner in it.
Old 07-23-2009, 06:52 AM
bookmark
Old 01-26-2023, 01:34 PM
AndrewCologne's Avatar
Here's all you need:
https://nineelevenheaven-wordpress-com.translate.goog/der-911-us-sc-3-0-motor-mit-g-kat/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de
https://nineelevenheaven-wordpress-com.translate.goog/abgasregelung-beim-sc/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de
(Translated viy Google)
EDIT: uops, sorry I just recognised the Thread is from 2009!
Don't know why Porschedude just posted a "bookmark"
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 01-26-2023, 08:29 PM
I wanted to save interesting reading and information on CIS.
Old 01-26-2023, 09:15 PM
