-   -   Help Installing Pertronix-Strange tab on points plate (http://forums.pelicanparts.com/porsche-911-technical-forum/486892-help-installing-pertronix-strange-tab-points-plate.html)
pryord 07-21-2009 06:56 PM
Hi,
In the picture below, there is a tab at about the 12:00 postion on the plate that the points attach to. It's in the way of installing a new pertronix unit. What is it for? Can I remove it?
Thankshttp://forums.pelicanparts.com/uploa...1248227791.jpg
pryord 07-22-2009 06:35 AM
Anyone?
dhrcr911s 07-22-2009 06:47 AM
ran into problems trying to get a pertronix into my car also. If you figure it all out, do a tech article.. Is it going into a 67 S?? If so, what kit number are you using. As i remember, there was no pertronix kit that fit the 67 S dizzy.. Bob
pryord 07-22-2009 06:52 AM
Yes, it's for the '67S. Pertronix said the kit 1866 would work. I guess it's a fairly new one. It's basically the 1844 unit with a different a different sleeve to work with a 6 cylinder engine.
dhrcr911s 07-22-2009 07:01 AM
I'll have to resurect my project now... Modify the plate if you don't intend to put points back in the car, but be aware that if the pertronix fails, which they are known to do, you might be stuck without the ability to put points back in the car wihtout that piece there.
Maybe find another plate??? One you can sacrifice. Bob
BTW, what's the chassis number on your car??
pryord 07-22-2009 07:07 AM
It's 308473S.
I didn't take a picture before taking the points off, but I can't see what purpose that tab serves. ..at least for my car.
304065 07-22-2009 07:29 AM
David,
That tab is only present in the vacuum advance distributors-- it was probably scavenged from a vacuum advance 68 911T. Here is a picture of my '66 '001 distributor, you can see the tab is not present.
http://forums.pelicanparts.com/uploa...1224210190.jpg
I think you can grind it off. I don't use electronic ignition BTW because I can't see when it fails.
dhrcr911s 07-22-2009 10:21 AM
Picture..
My Dizzy plate is the same as John.. Gap is looking like it might be a little small.. Hmmm Bob
http://forums.pelicanparts.com/uploa...1248282909.jpg
pryord 07-23-2009 06:30 AM
Thanks for the help guys. I'm going to grind the tab off mine and begin looking for an original style plate.
dlague 07-23-2009 09:41 PM
I have had a Pertronix in my 1973.5 for a couple of years and love it. I have a spare set of points and a spare Pertronix in my tool kit I carry in the car. Never had to use them..........Pertronix is an VERY VERY good modification for these points engines.
