peppy's Avatar
steel head studs rusting
I am still in the process of getting parts for my rebuild, that is going on 2 years. I noticed this morning that the steel studs on the case have a lot of surface rust on them.
I plan on just replacing the top row with steel. is there something I should put on them to stop the rust or just leave them alone?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 07-22-2009, 10:14 AM
Mo money = mo parts
I am getting ready for the same, so will be interested to see what other responses. According to Wayne's book, the head studs should NOT be media blasted. I will probably use a brass wire brush to remove the corrosion, then paint with a high temp rustoleum paint.
You may get a few more responses on the engine rebuild forum.
Also, I think you mean to replace the lower, not upper head studs. The lowers are the exhaust that are dilavar which tend to break, especially when re-torqued.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 07-22-2009, 10:57 AM
peppy's Avatar
Greg you are correct, I should have said the lowers.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 07-22-2009, 03:41 PM
Zeke's Avatar
I would simply clean off the rust and treat them with an oil. If your cylinders are not installed yet, you could heat them a bit and rub the oil in.
Or buy some Carwell stuff. http://store.carwell.com/
Old 07-22-2009, 04:12 PM
