Hey Guys,
Whats a good sealer for the tail light housings? The old stuff definitely wont be doing the job again. Thanks, Gene |
I just used plumbers putty. Not sure if that's the best thing to use but it's what I had on hand.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
I used a bead of silicone to make the gasket for the rear metal plate to seal the housing. Like many, the old putty in mine simply crumbled in to a large mess.
Recreational User
I just run a bead of waterproof caulk all the way around. The screws are what hold the back plate on anyway, so all you need is something to keep the water out.
Yeah, I was thinking silicone too!
Thank you guys! |
Schleprock
Are you referring to the sealant that closes up the rear cover plate on the light housing? Or the seal between the taillight lens and the housing?
For the rear cover plate, I used rope caulk for windows in your home. Got it from Ace Hardware
Kevin L '86 Carrera "Larry" |
This what I used (although mine is grey). Also used it between body and fenders.
Champaign and Burgundy 3.2 (1986) Ex-C4 91 Ex C4 93 A8 3.0 TDI X5 |
mine have a white rubber gasket.?
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
Designer King
Some Home Depots carry a glaziers' tape, which is an elastomer w/ one adhesive side. Looks like what Garp posted, except comes on a roll, in silver or black.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Yeah, the cover on the back. The rope caulk sounds to be the least messiest method
Thanks guys! |
