993 brakes
This is my first time changing a set 993 front brakes. Is it common for the pads to have a really tight fit. I have to force them in. I check the pads they are exactly 132 MM wide. Any information would be greatly appreciated.
Old 07-26-2009, 06:39 AM
MBruns for President
JeremyD's Avatar
The stock ones have "spiders" that dampen the noise. The spiders actually "fit in" the cylinders and make them a tight fit. Sometimes you have to remove the caliper to change the pads - if it has stock pads. PITA
Old 07-26-2009, 06:48 AM
Bill Verburg's Avatar
he ss pad holders can get a buildup of mung & corrosion behind them, this reduces the room for the pads to expand them to fit.
The cure is to remove the ss holders and clean behind them
Bill Verburg
Old 07-26-2009, 07:43 AM
JeremyD's Avatar
In rather than out - I get it - yes brake pad deposit 0
Old 07-26-2009, 08:00 AM
