I know it's a stupid question, but I'm really clueless...
I know that by running your car without an oxygen sensor, you will waste 30% of your fuel, the car will hesitate, etc. Then why to people run without oxygen sensors?
My SC didn't come from the factory with an 02 sensor. It runs great.
What year car do you own?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I was trying to replacemy O2 sensor the other day and the old connector broke. I haven't noticed the slightest difference. That said, my wrench buddy adjusted teh mixture while I was trying to find a replacement part online so I don't know how much of an adjustment he had to make.
However the plan is to put on a cat bypass (reduced heat mostly) and run the O2 sensor when I fix the connector. So I too am curious as to the reasons folks would run without one given that they still have the original fuel delivery system (CIS, Motronic,Etc...)
1983 SC - sold 2002 996 C4S - sold 1968 912 Last edited by mickey356; 07-26-2009 at 01:46 PM.. |
Author of "101 Projects"
Different fuel systems have different uses for the O2 sensors, so unplugging it on one car may be differently than unplugging it on another car. For example, my 959 does not use an O2 sensor - it gets all the information it needs from the airflow meter and other sensors on the car. Yet, on more modern 911s, you can run into "limp mode" and other problems if you have faulty O2 sensors (plus your car won't pass emissions tests).
In general, it's best to run with the O2 sensor connected as it helps to keep the mixture properly adjusted on most cars. -Wayne P.S. There's no such thing as a stupid question here!
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I have been running my '87 911 with the o2 sensor disconnected for about 3 years now, I only connect when I have the car smogged.
With the sensor connected the car runs much rougher at idle and low speed. It's still drivable but much more smooth without the sensor connected. Now maybe my car has an underlying problem, but for me its better without the o2 sensor.
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
In the case of the early O2 sensor systems, the sensor only functioned at idle/partial throttle. It was very much a "clever hack" to make sure the car provided good emissions. In reality, a non-O2 CIS should perform the same if tuned properly.
I think the real reason is that its easier to tune off-design with the O2 system not interfering in your attempts to run the system a bit more rich for power. Of course, in some cars removing the O2 will cause problems because the fuel map is setup specifically to be corrected by the O2 sensor. In this case, the engine will run poorly as its running the safest setting it has.
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
If the car is tuned right is should proform well without the O2.
CIS cars however can save a fair amount of fuel with the O2 hooked up. I have mine disconected on my 3.2. |
On the highway I still get 25 mpg. I don't think that the 02 sensor would provide much (if any) improvement.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Designer King
No O2 on mine for about 17 years. Runs great! And recently when it didn't, it wasn't because of the O2 being disconnectd.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
The sensor on my 911SC was disconnected by a previous owner and the car runs great. Passed WA emissions as well, although John Walker had to tweak it a bit.
No O2 sensor in my '86 3.2. Better throttle response, idles better, runs better. I did get a drop in mpg. With the O2 plugged in I got around 22 mpg in mixed driving. Without the O2 sensor I now get 18 mpg in mixed driving. Worth the trade off IMHO.
Al |
