Help with torsion bar calulations please
I am trying to understand how much sway bars contribuite to the wheel rate.
Can someone help figure out the following torsion bar/ lever length's in pounds per inch?
38" torsion bar length with a 13.5" lever on one end in the following diamters:
25mm
24mm
22mm
21mm
19mm
38" torsion bar length with a 10" lever:
25mm
24mm
22mm
20mm
19mm
18mm
Thank you very much if you can help.
Old 07-27-2009, 06:26 PM
Roc Doc's Avatar
SAW used to have an effective spring rate calculator on their website. You'd need to know the spring rate of each spring though.
1976 911S Targa, Carrera bodywork, 3.2l engine.
Old 07-27-2009, 06:58 PM
Visit rennlist.com,go to technical forums,then suspension and torsion bars. Has all the
formulas.
Old 07-27-2009, 09:58 PM
Thank you for the input guys.
I wish I had the math skills to do it myself. Once I get past percentages, compounding, and or the volume of a circle I start to get lost.
I need help.
Old 07-28-2009, 06:02 AM
burgermeister's Avatar
k = (3.14159*d^4 * 80000 / (32 * bar_length)) * ( 25.4) / (4.448 * lever_length^2))
bar length, lever length, and radius in mm
pi* d^4 * G / (32*L) is the stiffness in N*mm/radian (G = 80000 MPa, pi = 3.14159...)
/ lever_length^2 converts to linear stiffness (N/mm)
* 25.4/4.448 converts to pounds / inch
Assuming I didn't brainfart something ....
Edit: Brainfarts indeed ... and lots of them ... have been corrected. I Think. That's what I get when not resorting to reference material.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 07-28-2009, 05:09 PM
Thanks Burgermeister.
That is all greek to me but thanks.
Old 07-28-2009, 05:12 PM
