brake light switch?
I notice yesterday that my brake lights are not working. is the switch mounting on the mastercylinder? I assume 1 of the switches on the MC are brake lights and the other is for the brake warning light however do not see this avialable as a sepereate part any thoughts?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-30-2009, 05:33 AM
MBruns for President
JeremyD's Avatar
replace both - yes, on the master cylinder - they are a known weak point.
Old 07-30-2009, 06:44 AM
Oh Haha's Avatar
If you have a buddy hold the brake pedal down while you change them, you don't need to bleed the brakes when done.
Have them just put pressure on the pedal, you then take out the old, install the new and then they let off of the pedal. DO NOT let them push it to the floor!! Just a firm pressure is all that is needed.
Pacific Blue
Wayne
Old 07-30-2009, 12:59 PM
emac's Avatar
Wayne---don't want to start anything but I wouldn't put any pressure on the brake as this would cause fluid to squirt out while you disconnect the lines. When I did mine which took about 10 minutes once I removed the brake lines they weeped just a tad. With that I knew that no air was entering the system. Once finished I didn't even have to bleed the system.
Ernie 81 SC
Old 07-30-2009, 03:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Ben just PMed you, if yours is a 3 pronged, ignore my PM.
'85 Carrera Targa
PCA/POC
Old 07-30-2009, 03:46 PM
Oh Haha's Avatar
emac-no problem.
Everyone has a way to get a job done that works for them. My wife helped me and it worked out great. Just some dribbles from the sockets in between changes on the switches.
Pacific Blue
Wayne
Old 07-30-2009, 04:01 PM
replaced the front one with one from the local vw shop and all is good. I need to replace the back one yet but glad that was all that was wrong
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-30-2009, 04:05 PM
