Sunroof Liner
I've read all the posts... and this is still not clear to me:
Do the edges of the sunroof vinyl liner run in the side channel of the cable channel? Or between the top of the cable channel and the sunroof? I'm having difficulty... thanks, Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
XLR8'd Member
I have the same problem and ruined mine trying. Now it is "topless". The liner that is...As far as I know it runs between the rails and the roof needs to be off to put it back on. Pain in the butt.
David (mechanic wanabe) 2002 Carrera 4S (replacement for an 84 coupe) 06 Acura CSX (wife beater) 05 Acura MDX (toy hauler) http://www.pelicanparts.com/gallery/david_84_911 |
Jim,
go to the Tech Info Center on this site and scroll down to the Miscellanous section and you will find the step-by-step instructions on how to install the sunroof liners. I believe those instructions are right out of Waynes book "101 Projects for Your Porsche 911". And take it from me, it won't hurt to order 2 sets of liners. I replaced mine a while ago and it's very hard to get it looking like a factory installation. I simply did not take my time on this project and it came out a little crooked. Hope this helps Tim G. |
Thanks Tim - but I've completed everything but the reassembly of the liner back on to the sunroof.
I've made a lot of reference to wayne's step-by-step and other's as well...but no one is clear on my question. They all say 'slide the liner' back, or 'slide the liner' out...but never say if the liner is in the side groove or on top of the rails. I'm thinking in the groove.
A picture of your car highlighting the specific area in question might help.
I've redone my sunroof, but it is not clear to me from the written description what you are talkng about.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." Last edited by coloradoporsche; 04-08-2006 at 04:18 PM.. |
OK - here's an edge on view of the channel - that the wide groove on top of the channel has the rear sunroof bracket/cables run; on this side groove the only thing that clearly goes in it is the front sunroof bracket which 'spans' one edge of the groove.
So, this is the side groove (both sides) I'm thinking the sunroof liner slides up and back on (or not?).
Oooh,
now I know what your talking about! Sorry bout that jim. Although my interior is not completed I'll have to take a look and see what my setup is like. Tim G. |
This may not help much but I recently had my sunroof replaced when the car was painted - the windows were out, etc. but the sunroof was in. I took it to a little mom & pop upholstery place and I know for a fact that they did not remove the sunroof to replace the headliner. I only mention it because David 84 911 said you have to remove the sunroof and I don't think that's the case. Good luck with this. Its why I didn't attempt the job myself. The little shop did it in a full day for only $160! The headliner was an Autos International piece from their booth at last Fall's German Autofest in Ventura.
Dan in Pasadena '76 911S Sahara Beige/Cork |
This may not help much but I recently had my sunroof replaced when the car was painted - the windows were out, etc. but the sunroof was in. I took it to a little mom & pop upholstery place and I know for a fact that they did not remove the sunroof to replace the headliner. I only mention it because David 84 911 said you have to remove the sunroof and I don't think that's the case. Good luck with this. Its why I didn't attempt the job myself. The little shop did it in a full day for only $150! The headliner was an Autos International piece from their booth at last Fall's German Autofest in Ventura.
bump
The answer is yes, it goes into the slot! I wrestled with this dilema a couple of months ago, and got it reinstalled. I couldn't remember how I did it, so I just went out and looked at my car, and now I remember! The panel is only attached with clips in the front, and sort of floats in the rear. The slot guides the panel when you close it. I remember I tried it the other way and no go! It is easiest to put in with the roof out. Good luck!
Grant |
Thanks, Grant. The floating in the rear is actually my problem. The liner is correctly in the slot, but the "float" causes a metallic rattle over bumps. Now that I know it's in there the right way, I'll dig for a solution.
