-   -   RSR clone, 2.7 or 3.6 (http://forums.pelicanparts.com/porsche-911-technical-forum/489908-rsr-clone-2-7-3-6-a.html)
rbogh901 08-05-2009 04:43 PM
There are those who say that a 3.6 conversion is financially not much different from a good 2.7 build. Certainly there are pros and cons. Authenticity and weight are considerations but so are power and efficiency.
This must be covered somewhere but I'm not finding it when I search. Maybe not the right search terms.
Macroni 08-05-2009 05:42 PM
Clone...... 3.6
Highly original RSR clone..... 2.8 + lots of $$$$$$s. This car was recently built by Kevin Jeanette of Gunnar Racing.
http://forums.pelicanparts.com/uploa...1249519204.jpg
http://forums.pelicanparts.com/uploa...1249518923.jpg
http://forums.pelicanparts.com/uploa...1249518942.jpg
http://forums.pelicanparts.com/uploa...1249518965.jpg
http://forums.pelicanparts.com/uploa...1249518986.jpg
http://forums.pelicanparts.com/uploa...1249519004.jpg
About as close as you can get to an actual RSR......
ninelevenick 08-05-2009 07:08 PM
Wow, that is GORGEOUS.
deshetlr 08-05-2009 07:12 PM
So did you drive it to Keystone?
Macroni 08-05-2009 07:42 PM
Not mine, but yes it was driven by its owner Lee a fellow Pelican.
Jack Olsen 08-06-2009 09:19 AM
What do you want to do with the car?
rattlsnak 08-06-2009 03:41 PM
Look at it from the other side. if you were looking to buy one, would you rather have the one with a 2.7 or the one with a 3.6?? me?? 3.6, no contest..
GaryR 08-06-2009 04:57 PM
Do you know where those seats were sourced?
Macroni 08-06-2009 05:21 PM
I believe GTS. xtra wide STs
GaryR 08-06-2009 05:50 PM
I thought so but thanks for the confirmation. I would get the wide set also as it's for a road car..
davec 08-06-2009 06:45 PM
Back to the last pertinent question; what do you want to do with the car? If I had my last 2.7 build to do over again, it would absolutely be a 3.6. They have great power, still use pump gas (if you build a hot rod 2.7, raise the compression ratio, it requires higher octane), and, the 2.7 is noted for leaking, errr, marking it's territory.
DW SD 08-06-2009 07:35 PM
3.6 is a very user friendly package. You can still do it vintage looking with ITBs, carbs, too.
Doug
