Eye of the Toiger
3.6 Oilcooler conversion for a 74 911 3.6 conversion
Anyone got any info about doing a 3.6 Oilcooler conversion for a 74 911 3.6 conversion.
I have the front oil cooler set up I wanted to do the engine mounted conversion. Any help apprciated. Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Matt,
I did a 3.6 into '80SC conversion way back in "92, when no one had much "how to" info, much less kits! Not knowing any better, I was alarmed when I saw no engine mounted cooler. So I decided to add one for the extra cooling. Very simple to do, you just need a thermostat, a cooler, some rubber grommets, and you need to drill a couple of holes! Go to my thread on this subject, and you will see how easy it is. Good luck, Grant 3.6 transplant oil cooler question |
