sbrown.nw's Avatar
which header with heat exchangers to upgrade to on 3.2 euro
Hello,
I'm sure there is much debate on this, but I was wondering which headers are the best bang for the buck with heat. I was considering GHL (if you can find them), B&B, flipped 993 and SSIs last since I've been told that they are not quite big enough for a 3.2, especially Euro. Also, I was thinking of going with a Dansk Sport 2 in 1 out muffler - maybe with a removable capped 2nd rally tip for autoX and DE events welded on the right side pointing down so I don't have to cut my valence.
TIA very much,
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 08-10-2009, 09:02 PM
