Euro SC Differences
I have a'79 German market SC and I was wondering if the motor or gearing is different from a Californian SC as I had one of those a couple of years ago and the Euro SC seems quicker. I've tried to search the forums but "SC" seems to cause problems.
Thanks,
Kevin
Old 12-19-2007, 10:42 AM
Free minder
Aurel's Avatar
Do a search for ROW. Row SCs have more power (204 vs 184 if memory serves me) because of higher CR and less emissions restrictions.
Aurel
Old 12-19-2007, 10:53 AM
Bill Verburg's Avatar
Thanks,
Kevin
My79
RoW use 930.03
US 49 state use 930.04
US Cal. use 930.06
All are rated the same 180hp@5500, but .03 189ft-lbs@4200 while .04 & .06 are 175ft-lbs@4200
all have 8.5 cr
.03 max 6800+/- 200 governede by ignition cutoff, .04 & .06 max 6700+/- 300 governed by fuel pump cutoff
all use the same 915/61 trans
Bill Verburg
Old 12-19-2007, 12:00 PM
durn for'ner
livi's Avatar
Bill is the guru, but I just seem to remember that the 78 SC had 180 bhp but already the next model - 79 - got 188 in Europe. Or was it in 1980 first ?
Markus
Resident Fluffer
Carrera '85
Old 12-19-2007, 12:44 PM
PeterRT's Avatar
Yes, the 930/09 came for the 1980 MY.
Old 12-19-2007, 12:57 PM
My80 RoW SC uses 930.09 8.6cr, 188hp@5500, 189ftlb@4200, 915/62(same gearing as 915/61 except taller 5)
My81-83 RoW SC uses 930.10 9.8cr, 204hp@5900, 190ftlb@4300, 915/62(same gearing as 915/62)
Bill Verburg
Old 12-19-2007, 01:05 PM
Capitalist and Patriot
911Freak's Avatar
Am I missing something?
According to my COA and engine #'s when imported in 1988
My Row '81 SC Row came with engine# 6312077
930/10 - 204hp@5900 rpm & 268 ftlb@4300
9:8 cr
Trans: 915/62 #7312290
am I missing something in this thread?
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 12-19-2007, 02:51 PM
9:8 cr
MY81 engine# 6312077
6 - 6cyl
3 - 911SC RoW 3L, 150kW, 204 hp
1 - MY81
2077 - consecutive serial #
930.10 9.8cr
hp\DIN 70020 204hp@5900 = 150kW = SAE net J 245 145kW/195hp
torque\ DIN 70020 267NM@4300/ 27kpm = SAE J 245 258NM/190ft-lb
MY81 trans# #7312290
7 - 6cyl
3 - 5 spd
1 - MY81
2290 - consecutive serial #
915/62 8:31cwp
11/35 18/33 23/29 26/26 28/22
Bill Verburg
Old 12-19-2007, 03:17 PM
911Freak's Avatar
Thanks Bill! Any idea if the Trans is a LSD? I leave dual black marks when the tyres break loose. I know there should be a /12 following the 615/62, but the tab was machines or ground on a speed bump and really can't read it...
Thanks again for your wealth of knowledge!
BTW I have another 3.0 & 915:
#6402814 that's a 930/07 right? any worries about this engine?
And another 915 too: 915/62xxx (unledgable) #; 731 0964
Is the 3.0 #6402814 a good starting place to build a nice EFI 3.2l? ( 98mm, 9:8.5 cr,)
Does this engine have the larger valves some of the older ones do?
Again, thanks for you wealth of knowledge!!!!!
Old 12-19-2007, 03:57 PM
to tell if a 915 has an lsd raise the rear and spin a tire by hand, if the other side spins the same way there is a functioning lsd.
Yes, 930.07 MY80 US/Cdn. 3l SC. All SCs hve the same 49/41.5mm valves and cams. The difference was in port size and cam timing. MY78-79 have 39/35mm ports, MY80 up have 34/35mm ports. Bigger isn't always better. It would depend on how the heads interface w/ any replacement cams, EFI and gearing
Bill Verburg
Old 12-20-2007, 05:55 AM
constaf's Avatar
Gentlemen,
I currently race a 1980 Weissach edition in PCA club racing as D stock. I am thinking of going to E stock next year by rebuilding the motor as a 81-83 ROW. Are the trannys the same? Or will I have to change some gears in order to show up as ROW stock?
Old 08-10-2009, 05:50 AM
Originally Posted by constaf View Post
Gentlemen,
'80 US used 915/63 5th is 28/23(.821 OD)
'81 - 83 RoW used 915/62 5th is 28/22(.7857 OD)
the only difference in gearing is in 5th as noted above, the USA version is a noted shorter geared
Bill Verburg
Old 08-10-2009, 06:24 AM
