spsfiend's Avatar
What grease do I use for Elepahnt Racing oly Bronze Bushings?
My bushings are getting squeaky and I would like to grease them via the zyrc fitting. Can someone please advise me of what grease to use for Elepahnt Racing Poly Bronze Bushings?
Thanks!!
Old 08-16-2009, 11:07 AM
I would suggest you contact Elaphant Racing and ask them. Chuck is great about answering questions like that.
Old 08-16-2009, 12:19 PM
jkh2cpu's Avatar
Hi. I just installed mine. The directions state: "Note -- PolyBronze Spring Plate Bearings should be lubricated at installation and every 3,000 mile intervals or annually. Race cars should lubricate more frequently. Use quality moly grease." For quality moly grease, I bough the most expensive moly grease, which was the only moly grease ;-)
HTH.
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 08-16-2009, 01:41 PM
porsher
aston@ultrasw.c's Avatar
I used this. It works great on axle U/Js which are exposed to enormous forces, water, sand etc...
http://www.ctmracing.com/storefront/storefront.php?function=viewproduct&startrecord=0&productid=8&categoryid=4
Old 08-16-2009, 02:27 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Try this, it's the same grease I use in my CV's..
http://www.swepcousa.com/lubesite/products/101.htm
Gary R.
Old 08-16-2009, 03:10 PM
DanielDudley's Avatar
CV grease can be the easiest to get.
Old 08-16-2009, 05:53 PM
from your site
"This grease is engineered with PurePower! EHP® to bond to metals and provide the greatest film strength available to ensure the best possible lubricant protection for industrial as well as fleet and automotive use."
I like grease that sticks like glue. I take a dab between index & thumb and see the distance stretched by the grease.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-16-2009, 11:06 PM
porsher
That's the Gorilla Snot (ansi) test!
Old 08-17-2009, 12:53 AM
I bought that stuff from Performance before computer/Pelican days to use on my Welt street t-bar bushings. It was listed as suspension bushing grease. It's trully gorilla snot once you see it.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2009, 12:22 PM
