930 brake rotors Thickness?
Have a set of existing brake rotors I would like to turn down. Require a little information looking for the thickness tolerance for machining brake rotors for a 1979 930. Bentley does list. Info would be appreciated.
Old 08-12-2009, 09:45 AM
DW SD's Avatar
can you have them ground as opposed to turned - this would ensure them being flat? The minimum thickness is printed right on the rotor.
I had a hard time finding someone to grind them as opposed to turning.
Doug
1971 RSR - interpretation
Old 08-12-2009, 10:58 AM
Assuming you are referring to front rotors, these are 32mm thick and must be replaced when they are 30mm thick.
These should be Blanchard ground, never turned on a brake lathe.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-12-2009, 02:38 PM
Bill Verburg's Avatar
front 32mm new 30.6mm symmetrically machined from both sides
rear 28mm new 26.6mm symmetrically machined from both sides
I agree w/ Steve ground is the only way to go, it leaves a nice swirly finish that promotes pad bedding
Bill Verburg
Old 08-12-2009, 03:37 PM
