-   -   front sway bar mounting tabs (http://forums.pelicanparts.com/porsche-911-technical-forum/491295-front-sway-bar-mounting-tabs.html)
Christien 08-12-2009 07:15 AM
I want to install a front through the body sway bar, so went out to check if I already had mounting tabs. What I have don't look like any pictures I've seen here in researching this. Can anyone tell me just what the heck these are?
Thanks!
http://forums.pelicanparts.com/uploa...1250086494.jpg
ChkbookMechanic 08-12-2009 07:21 AM
Those look like the loops to hold a front underbody sway bar in place.
The Smart Racing Sway bar comes with tabs to mount it on the a-arm. The Tarett requires you to buy the tabs and have them welded to the a-arm.
Christien 08-12-2009 07:22 AM
Does that mean my a-arms have been transplanted from a later car?
trak ratt 08-12-2009 07:25 AM
Those are the tabs for the under body sway bars used on later cars. If pic is of your LH then the a-arms have been replaced with later arms. There's a "kit" that replaces those with the earlier mounting tabs available from Pelican. I'm upgrading my sways on the SC and have that kit. Just need to cut the existing tab off, drill hole through a-arm and use the bolt supplied with the kit to mount tab. Can also be welded in place like those.
tobluforu 08-12-2009 07:30 AM
Bring car to muffler shop, and weld them on.
KTL 08-12-2009 07:57 AM
Yes. The underbody front sway bars appeared in 1974.
RWebb 08-12-2009 11:24 AM
interesting - you might have the improved brake caliper mounts & struts too
Christien 08-12-2009 11:48 AM
How can I tell? Take pics and post them and have you tell me? :)
911st 08-12-2009 04:04 PM
Look at the cross bar that holds the A arms. On a 72 it was steel. 74 and later were alloy. Also, look at the spacing of the bolts that hold the brake calipers. I think the 911T had 3" space, later cars and S models had 3.5". And, look at the thickness of your rotor. If it is 24mm you probably have a front end off an 84 or latter Carrera, if 20mm it is a74-83 911 . Lastly, are you calipers made of cast iron or alloy?
911st 08-12-2009 04:05 PM
PS, stock 86-89 front sway bars are 22mm and inexpensive but not addjustable.
