nameisbauer's Avatar
Send a message via AIM to nameisbauer
When did Galvanized bodies start?
I read in some places 1975. Some in 1978.
"In mid-1975 Porsche began dipping its formed sheet steel body panels through an electrically charged 930 deg. bath of zinc. At this temperature, the zinc bonded galvanically to the steel. Every steel surface in the car body was "galvanized" at a manufacturing cost of nearly $100 per car (1975 911S base cost $11,875)."
If this is true, how do you tell which 1975 models are and which are not?
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 09-04-2009, 03:33 PM
DUK DUK is offline
DUK's Avatar
Galvanizing on Porsche 911s - A History
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 09-04-2009, 03:51 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
If it's rusted, it's not galvanized.
Galvanized metal looks different. If you chemically strip the paint off, galvanized panels will have a bit of a "scaled" look to them. Smooth, but slight variations in coloration (usually little square-ish shapes around 1cm-2cm across). Regular metal looks more uniform in coloration/appearance.
Black Cars Matter
Old 09-04-2009, 03:53 PM
Information Junky
island911's Avatar
the short answer is, Porsche slppery-sloped the galvanization of the bodies. Being that it adds cost and weight, the early 70's had just the floor panels (and some bits) done, and by the SC they were fully galvanized. --IIRC
Disclaimer: the above was 2˘ worth.
Old 09-04-2009, 04:09 PM
Thanks guys, I wish that original history came up when I searched.
1970 – Galvanized steel (not Thyssen type) used in floor pan and wheel arches (Bob White in Pano V: 142); the “entire platform, including the floor, the longitudinal members, the wheel arches and the seat pans were galvanized.” (Boschen & Barth, p. 124)
1971 models – had galvanized steel in areas particularly exposed to rust (Frere, p. 201)
1972-1973 – Thyssen steel use began (Bob White in Pano V: 142)
1973 – Thyssen steel: rocker panels, inner rocker panels, floor pans, & some other parts (Chuck ******** in Pano V: 142)
1975 – Thyssen steel: entire body treated (Bob White & Chuck ******** {began in Feb. ’75 production for US cars; earlier for Euro cars – had trouble with paint} in Pano V: 142, 192)
1976 models – had Thyssen steel in entire body except roof (Frere, p. 201)
1977 models – on – had Thyssen steel in entire body (Frere, p. 201); an “important step forward was the use of zinc-coated sheet steel for the manufacture of the entire body structure (except for the coupe’s roof on early production cars). Coated on both sides, this made the structure virtually immune against the formation of rust….” (Boschen & Barth, p. 143)
Jim
Old 09-04-2009, 04:38 PM
AutoBahned
RWebb's Avatar
what search terms did you use?
you could add them to the thread -- I made up the thread b/c this is a pretty common question. so it would be nice if people could pop up the researched answers quickly
Old 09-04-2009, 04:40 PM
jkh2cpu's Avatar
Name is Bauer is on the money. My factory manual says on the top of page SB 39: Beginning with 1970 models, the vehicle undercarriages are made of galvanized steel and sheet metal sections.
Vehicles with the following chassis numbers are excluded:
911 012 0011 to 911 012 4126 and
911 022 0011 to 011 022 06667
911 112 001 continuing
HTH.
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 09-04-2009, 04:47 PM
Zuffi-Freund
Hesse James's Avatar
Send a message via Skype™ to Hesse James
Hello,
However galvanisation was a big step into the right direction. Especially when Porsche came up with it in the late 70ies. In Europe at that time nearly the whole car industry used steel from minor quality (recycling steel coming from eastern countries) that lead to severe rust problems especially in the mid 70ies. Cars from that period of time started rusting when sitting and waiting for delivery to the customer.
But galvanisation does not mean no rust. If the surface is not proper sealed, it will rust like any other non galvanised steel - only later, if all the zink-galvanisation is gone. You can see it whwn you look at old rail-guards that are fire-galvanised but not coated - after the surface is gone, rust will appear. Same with old porsches - especially if the surface is not conserved or painted, poor repairs or welding after accidents and so on. I've seen so much galvanised SC cars in Germany that wre fully rotten by permanent driving on salty roads. Those cars look like a non galvanised car - only 20 years later. So everybody should be aware, that all porsches - galvanised or not - are subject to corrosion (especially because those cars are kept longer on the streets). If you live in a region with salty roads in winter, or dirctly at the sea - you should take action to preserve your car - or you should not drive your car in such conditions.
best regards
HEiko
best regards
Heiko
Porsche 911, 74 Lachs-Diamant Metallic
Old 09-05-2009, 12:53 AM
