-   -   Newbie 3.2 Liter Start-up issue (http://forums.pelicanparts.com/porsche-911-technical-forum/492081-newbie-3-2-liter-start-up-issue.html)
kamps 08-16-2009 05:12 AM
Hey all - need a little help! Well, alot of help actually.....
I have a '75 Carrera with an '86 3.2 liter engine in it - problem occurs just after starting - engine starts up fine but then seems to bog down - almost like it's drowning itself. It chugs for a few minutes and then settles down to a proper idle.
This sometmes occurs when driving but primarily after start-up. I've checked for vac leaks - found and corrected a couple - but there is obviousy something I'm missing. Also getting copious amounts of smoke after it settles down.
Any suggestions?
Thanks for your help.
DUK 08-16-2009 05:21 AM
How do you have the vent hose for the oil tank ran? Are you using the hose from the 3.2? Can you post some pics? I'll try and help, I've got a 87 3.2 in mine but I'm running megasquirt so I may not be able to help in the ecu dept.
Brother 08-16-2009 05:27 AM
Sounds like the CHT probe is inop.
kamps 08-16-2009 06:17 AM
newbie 3.2 start-up issue
thanks gents.
I'll check the oil tank line.....
What's the CHT? DUH!
DUK 08-16-2009 06:29 AM
Cylinder head temp. It's on the front (trans side) of the #3 head. It plugs in at the connector on #3 intake runner.
Brother 08-16-2009 06:43 AM
Check out Part #: 930-606-915-00-M14 in the pelican catalog. There is a technical article linked under the Notes tab.
kamps 08-17-2009 06:01 AM
3.2 Start-up Issue
Thanks for all the feedback. As soon as I can check this all out I'll let you know the outcome.
