92 roadster offset?
Hi guys. Does anyone know the wheel offset for a 92 roadster? Thanks for any help.
It's the same as the turbo.
Amir '83 911SC |
Exactly! However, if you have the stock wheels, I believe the offset and width is cast next to the valve stem. I'd look at mine, but they are in storage. IIRC, the offset front and rear was et55.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
you do realize that o/s or ET is meaningless w/o the width?
stock '92 America Roadster came w/ 7 & 9 x17 both had ET55. Much wider can be fitted, w/ different o/s of course other wheels used on turbo body 964;8ET52 & 9.5ET68 w/ 17mm spacer
