Excellent SC Shifting
After three years of upgrades and tweaks, the shifting on my 82 SC is finally perfect. Here is a list of changes (almost all purchased from our host):
Shifter Bushings and Wevo Coupler - Major tightening up of shift process
Factory Short Shift Kit - Shorter throws - Had to spot weld the top and bottom pieces of the shift lever together after the epoxy bonding failed twice
Wevo Motor and Transmission Mounts with the softer black inserts - Further tightening up of the shift process - subtle change but made a big difference in that the shifter always operates exactly the same each time with these mounts in place.
Seine Systems Gate Shift - Got rid of the sloppy alignment between 1st/2nd and 3rd/4th. Another spot weld to attach the 1st/2nd gear clip to the shift lever.
Momo Anatomico Shift Knob (tall) and leather shift cover - Feels right, looks good
82 911SC Targa with Megasquirt EFI
Old 08-20-2009, 07:00 PM
scotricker's Avatar
That sounds like what I should be doing next..
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 08-20-2009, 08:24 PM
Senior Advisor
James Brown's Avatar
any transmission repair/upgrades?
08 Cayenne Turbo
Old 08-21-2009, 12:28 AM
No. I haven't changed anything in the transmission.
Old 08-21-2009, 04:21 AM
