-   -   Camshaft from a 2.4L Engine into a 2.7L Engine (http://forums.pelicanparts.com/porsche-911-technical-forum/493187-camshaft-2-4l-engine-into-2-7l-engine.html)
Julien 08-20-2009 07:11 PM
Can someone tell me if a camshaft form a 2.4L engine (piece # 911-105-142-00 & 911-105-141-00) can fit into a 2.7L engine (piece #911-105-144-00 & 911-105-143-00)?
Thanks.
Julien
Eagledriver 08-20-2009 08:58 PM
The cams will fit into the engine but the valves will hit the pistons when you turn the engine over. This assums you have a stock 2.7 with CIS pistons.
-Andy
stlrj 08-21-2009 02:52 PM
If these cams are off a 2.4 CIS engine which they appear to be, they will be fine.
Grady Clay 08-21-2009 03:26 PM
Like many things, - it depends.
The ’73.5 911T CIS cams are 3-bearing (nominal 47 mm).
The ’78 on 911 cams are 4-bearing (49 mm).
The later 2.7 (’76-’77?) Had undocumented 4-bearing cam housings with the 4th bearing oiling hole plugged. I have reason to believe there were 3-bearing housings used with 4- bearing cams (47 mm) – the 4th bearing just ran free. I have never seen a 2.7 with 4-bearing (49 mm) but I wouldn’t be surprised.
So – look at your parts carefully.
Above, the subject is piston-to-valve clearance. Critically important.
Best,
Grady
