I'm puzzled, doesn't this car have a CDI ignition system..??
Both my '78 and '88 do. So measuring the voltage across the coil would be meaningless unless you're doing it with an O-scope. CDI modules are a VERY common failure point, especially so if the car has a history of alternator/regulator/battery charging, OVER-CHARGING (smell that "sewer" gas..?) problems. |
84-89 Carrera is not CDI, it's a simple inductive coil setup (old school).
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Good news, as the rev-counter, tachometer, is driven by the CDI module. At least "some" indication that the CDI module is operational, but at a relatively minor level. |
The 84-89 does not have CDI. The tach pulses are generated by the DME from the flywheel ref sensor. If the tach is bouncing while cranking this is good. The pump will come on when key goes into 'START' and then the pump will remain on after engine starts, the DME will activate the FP and keep it on so long as engine is running.
Morning Everyone.
Thanks for all the info im passing it onto my friend who is working on the 911. With reguards the DME i did buy a new 1 last year and it still does the same (not fireing) on my old 1 it said 12v 15a and on the new 1 it says 12v 30a will this make any difference ??
Thanks JG911 |
Where on the DME does it say 12v 30Amp? So long as the 2 DMEs are for a 84-89 Carrera they should work.
But here is the bigger issue: if you have a bad (shorted) coil you will destroy both DMEs! You need to get those 2 DMEs into a known good car to be sure they do still work. Quote:
It says 12v 15a on the outside casing on the old 1 and it says 12v 30a on the new one i was told the new was for the same year,ill see if my mate can try them both in his SC
Thanks JG911 |
Let's start over on the no-start issue and not assume anything for the moment. When you turn the key to 'RUN' does the IdleControlValve hum and vibrate? If it does then the DME is alive. Test this first.
Im going to say yes as we can hear a huming from the engine compartment,and we can smell petrol.
Thanks JG911 |
You should not smell any fuel while in 'RUN' the injectors only start fueling when key is in 'START' - please be sure the ICV is humming with key in 'RUN'. I can walk you through diagnostics but it has to be step-by-step (no assumptions).
Also, get a LED test light (from Walmart less than $5.00) this is a 12volt test light but can not have a normal light bulb it MUST be a LED. You will need this type of tester to fully test certain components as we diagnose your problem.
ok let me buy a test light and take it from there :-)
Thanks JG911 |
Right guys.
We have replaced Rotor Arm Dizzy Cap Battery DME Relays x 2 Flywheels sensor x 2 Tryed my coil on my friends SC and it starts it fine,but it just keeps turning my engine over. Any ideas on were to look next ?? Bleedy thing.
Thanks JG911 |
Yes,
Get a LED test light and I can try to help you. First, when you turn key to 'RUN' do you feel and hear the IdleControlValve? if you do this means the DME is alive and the program code is running. Let's start here first.
Putting a coil from a 84-89 Carrera in a stock SC is not a good idea. The SC is a CDI ignition that hits the coil with 300+volts on the primary side! The Carrera is standard 12vdc ignition and the coil is designed for only 12vdc on the primary, I do not suggest using this coil with the CDI SC system.
Hiya yeh we only tryed it very very quickly and we checked my coil again after wards and it was the same,yes im off this friday so ill get a led tester.
What would you test 1st and what am i looking for ...
Thanks JG911 |
You are talking about the DME relay. It's a little black plastic box and as the name says it's a double relay driven by the DME. It has the markings you mention. The DME itself is the large rectangular silver box and that is the culprit. If you buy it that usually sets you back 500 - 1000$ depending on the source. But you can have it checked and repaired. It is what produces the spark by grounding the coil for fractions of a second. Use the LED test light and measure across the coil while cranking. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Just to be sure, your car is a 84-89 Carrera right?
First test is to see if the ICV is humming with key in run. Then connect the LED test light across the coils '-' and '+' terminals then crank the engine and the LED light must flicker. If it does not then you don't have coil pulses. Then disconnect an injector (any one you can get at easily) then connect test light across the 2 pins at the harness side you just disconnected. Again crank engine LED must flicker. If it does not you don't have Injector pulses. If you find you don't have Ignition or Injector pulses then most likely one of the FlyWheel sensors are not working correctly, either bad, out of adjustment or you could have them reversed, meaning they both have the same style connector so you could have plugged the wrong connector into the sensors (you have them swapped) this can happen if you replace both sensors and did not pay close attention to which one goes where in the bracket that holds them. So start by ICV humming - then coil pulses - then injector pulses. Let's start here.
Same issue here
The car was running fine, parked it in the garage...the next morning it wouldn't start.
Like any self respecting 911 owner, I promptly used my spare DME relay in the glove box and tried to start it without luck. I knew there wasn't any spark since the tach wasn't jumping while trying to start. Long story short, it was the reference sensor ( 911-606-215-01) that was causing the issue. New reference sensors and we are live again! |
Thanks JG911 |
Hiya guys iv just had auto sparky come round to give me his views and he put a very old gadget with lights on the coil and he says the coil is working the wrong way round it's got 12v going to it it just not switching over
On the gadget is was AMPS ON but was off and AMPS OFF mine was on .... Any ideas or should i now get me LED tester
Thanks JG911 |
