Straps Under Passenger's Seat?
Can someone tell me what these straps are for? I had though that they for the (missing) Porsche air compressor, but I have been told that they were originally stored in the trunk. The straps clip to the seat rails. (Disregard the baby seat strap that's hanging down from above).
![]() Also, while we're here, what are these electrical connectors for? My guess would be for optional seat heaters. Is that correct? Driver's side: ![]() Passenger's side (relay?):
1987 911 Coupe, Diamond Blue Metallic 2006 Cayman S, Seal Gray 1983 911 Targa, Black: The Dirty 911 (GRM) Last edited by Woodyhfd; 08-22-2009 at 02:57 PM.. Reason: Clarity |
I don't know about the straps, but the electrical connectors (at least the driver's side) looks like my connector for seat motors. Do you already have power seats?
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
I'm pretty sure the straps are for the passenger side floor mat (possibly an aftermarket one, to keep it from sliding forward). check for some clips on the underside of the mat.
I think the straps go through the front of the rail, and connect to that little hook on the back of the seat rail in your first picture.
Silver '88 RoW Carrera Grey '06 A4 Avant Last edited by TheMentat; 08-22-2009 at 03:22 PM.. |
Virginia Rocks!
The straps are for floor mats. The Lloyds mats uses that set up.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Recreational User
The connector on the driver's side is for the seat belt buzzer. Not sure about the one on the passenger side. It doesn't look familiar.
Irrationally exuberant
The big connector is for power seats.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks for the info.
The straps for the mats make sense now, as does the connector for the seat buzzer. I have the lower-end power driver's seat (height adjustable only, two buttons). So then, the big connector under the passenger seat would be for a power passenger seat I guess.
1987 911 Coupe, Diamond Blue Metallic 2006 Cayman S, Seal Gray 1983 911 Targa, Black: The Dirty 911 (GRM) |
For a while, a power driver's seat was standard and a power passenger's seat was optional.
JR |
