red hose
Can't seem to find a listing for the red hoses on rear of H/exchangers. Anyone know where to find them or a substitute? Can't seem to find them in Pelican catalogues
Old 08-22-2009, 11:35 AM
Wyvern's Avatar
I found on FleaBay
Brian
Old 08-22-2009, 12:35 PM
Johnb911's Avatar
http://www.dudiakracingproducts.com/index.php?main_page=index&cPath=405_2279_2283
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 08-22-2009, 12:37 PM
Senior Advisor
James Brown's Avatar
aircraft spruce has it and sells by the foot
08 Cayenne Turbo
Old 08-22-2009, 12:59 PM
KNS KNS is online now
It sounds like you are referring to the short sections of red/orange hose found on the 3.2 Carrera. They are: 930.211.339.01, "Exhaust Rubber Sleeve".
Kurt
Old 08-22-2009, 02:09 PM
Commerical Pilot
GLASFIBRE's Avatar
WICKS AIRCRAFT SUPPLY in Ill. It's called "Sact"
Old 08-22-2009, 02:21 PM
rubber hose
Thanks KNS: You're right on. Thanks to everyone for their input
Old 08-22-2009, 02:23 PM
i got 12 ft for $70 @ aircraft spruce. probably that much at the dealer for two short lengths.
206 637 4071
Old 08-22-2009, 02:29 PM
Not "sact," "SCAT." There's CAT, the cheapest and least durable or temperature-stable. There's SCAT, which is better and temperature-rated, and there's a third variety--can't remember what it's called, since my airplane wasn't pressurized and I didn't need it--that's double-walled and used for serious high-temp applications. If you really want to go high-tech to the max, that's your babe.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 08-22-2009, 02:34 PM
$27.50 a foot? Well, I guess it's "authentic." Or should I say OEM and re-open a recent thread?
Stephan Wilkinson
Old 08-22-2009, 07:46 PM
B D B D is offline
B D's Avatar
Last time I checked getting two 12" hoses for $27.50 was cheaper than buying a 12 foot tube for $70, plus it will at least be Genuine or is it OEM
68 911L
Old 08-22-2009, 07:56 PM
You can buy any length you want if you shop at an aircraft-parts store.
Stephan Wilkinson
Old 08-22-2009, 08:15 PM
hose
The hose I needed was for my '86 carrera and KNS knew it as Part no. 93021133901. It's 2 pcs about 4 inches each at the back of the exchangers near muffler. Fairly heavy and solid with no steel windings. Altho maybe that type would work also. I think the aircraft type is used on the forward part of the heating system (at the blower boxes)? Right?
Old 08-23-2009, 10:50 AM
yellowperil,
The part number I gave you was correct for what you're looking for. The other hose being referred to is for 1983 and earlier or if you wanted to back-date your heat. You didn't say what year car you had originally and I think that threw everybody off. Also located at the forward part of the HEs to the cabin as you mention.
I'm not sure of the diameter of 930.211.339.01 but the other hose may work as well (I've have not seen the SCAT stuff used there...yet).
Kurt
Old 08-23-2009, 12:41 PM
Yes thanks KNS., thats exactly what I wanted, as described in the part number diagram
Old 08-23-2009, 12:43 PM
