Je Ne Sais Quoi = Targa
Mikey83835's Avatar
Some IDA Weber advice please?
I have this usual diagram of the Weber, but all the jets/jet holders are on the opposite side, anyone have a exploded view or whatever view for that matter from the other side of carb?
Also, I have 3 bolts on "other side" of each carb that are lockwired, the diagram does not show lockwiring at all that I can see, anyone know what these are?
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 08-27-2009, 05:57 PM
DanS911's Avatar
i believe the three bolts are the set screws for the venturies
Dan
'86 911 Targa Driver
'76 911 Targa 3.0 Track Toy
46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky)
Old 08-27-2009, 06:25 PM
68Sporto
MrJTP's Avatar
Don't over tighten those screws. They are just meant to hold the chokes in place. And the chokes soft.
I anticipated the situation you're in and as I took my Webers apart I took hi-res photos of each part as well as of the carb body itself. Then anotated the image of each part with the part number from the Weber image. Then Anotated the image of the carb body with location numbers for each part.
And added the location number to each part image of the body.
If your still lost on the blind side of the official drawing I can put the set up on a website so you can download them.
I don't think the drawing you have of the Weber is the same one I use but with the photos you really don't need the drawing.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 08-28-2009, 09:26 AM
68Sporto
MrJTP's Avatar
As promised to a couple of folks here is the link to all of my Weber assembly images
http://home.comcast.net/~ekchuah/Weber.html
Tony
1998 Boxster
Old 08-28-2009, 02:33 PM
Mikey83835's Avatar
Thanks MRJTP
Old 08-28-2009, 07:31 PM
