Location: A scenic and exhilarating drive along the Delaware River just one hour from Philadelphia, PA
Help with seat belt mounting points for early 911
I have the 4 point harness pictured below and also a guide bar that runs between the targa bar on my 1970. The top rear of the harness is routed over the guide bar and then the two mounting points on the harness are attached somewhere in the back of the car, probably the existing rear seat belt mounting points. My problem is the carpet is covering any existing (if any) rear seat belt mounting points. I hate to drill any unnecessary holes in my car if I don't have to.
My questions are: 1) Were rear seat belts an option on early 911's or do all 1970 911's have a total of 4 mounting points for the rear seat belts? If so where are they located? 2) Anybody know where the 2 front mounting points for driver and 2 mounting points for passenger seat belts are located? I would assume there must be some type of mounting points on the tunnel where the original seat belt receiver was bolted to but where is it? 3)Where would they be (if any) on the left drivers side between seat and door and the same place on passenger side? Any help is appreciated.
This picture gives you an idea of where they are: ![]() Quote:
This thread may be helpful: Question for 73 911 owners This is typical of the four points on the two seats: ![]() I would add that I would think long and hard about using the factory points for the lap belt sections. Starting in 1974, these points were moved off the seat and to a stronger location. Consulting with a local race shop that specializes in early 911's may be worthwhile.
Thank you Harry for the pic and the link. Your search abilities on this forum are obviously better than mine as I did not find that thread.
What is your intended use of the harness? If it is for De/competitive events, you need to verify that the group(s) you will be running with will accept the 4 point harness. The red Schroth Rallye 4 Harness in the picture above are the ones in my car (same as the ones you are proposing to use) and are not acceptable for use at PCA DE events.
