92 roadster offset?
Hi guys. Does anyone know the wheel offset for a 92 roadster? Thanks for any help.
Old 09-02-2009, 10:47 AM
ZAMIRZ's Avatar
It's the same as the turbo.
Amir
'83 911SC
Old 09-02-2009, 11:05 AM
WPOZZZ's Avatar
Exactly! However, if you have the stock wheels, I believe the offset and width is cast next to the valve stem. I'd look at mine, but they are in storage. IIRC, the offset front and rear was et55.
Old 09-02-2009, 02:08 PM
Bill Verburg's Avatar
you do realize that o/s or ET is meaningless w/o the width?
stock '92 America Roadster came w/ 7 & 9 x17 both had ET55. Much wider can be fitted, w/ different o/s of course
other wheels used on turbo body 964;8ET52 & 9.5ET68 w/ 17mm spacer
Bill Verburg
Old 09-02-2009, 03:53 PM
