Caveman Hammer Mechanic
Oil cooler details?
Hello,
I bought an oil cooler from a fellow pelicanite, and as wondering if anyone can provide any details, lik MFG ect. It was originally installed on a 1983 SC. ![]() The cooler ............... ![]() The thermostat ........ ![]() Thanks eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
That's a 'Turbotrol' unit w/ factory '74 -89 lines & t-stat. It's a good robust cooler for up through 3.2L.
Happiest when Tinkering
I have that cooler and it actually overcooled my system until I put all this other stuff on there. good cooler was about 900 bucks new 20+ years ago.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
As I said it's adequate for up through a 3.2, a 3.6 will overheat w/ just one of those coolers.
Bill although I cant find anything wrong with the thermostat I had in there you are probably right the thermostat wasn't working right but the one I have in there now works right comes up to 180-200 and hangs.
That's what it is supposed to do
I am looking for that exact oil cooler for my '74 911 that has no external cooler. May I ask what you paid for it?
Thanks. |
Post #3 Dont think it is made anymore.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 06-30-2009 at 12:36 PM.. |
Hello,
After swapping a hose that was not correct, I started the process of "The Install". I removed the oil from the tank, placed the hard lines on the body, with the thermostat loosely attached. The cooler used a bolt on the body that I am sure that was used on the trombone set-up. That left the upper mounting bolt to the body and a strap to the lower valence/horn bracket. The upper bolt was an issue, the nut would be under a hollow section right underneath the data plate. Got out the Rota-Broach and drilled 2 holes about 2" apart and opened the area between them so I could get my fingers on the nut. Got it all installed, replaced the rocker cover, added a 3 quarts of 20/50. and fired it up, crap the thermostat was leaking, 3 of the 4 lines were tight. As I was warming the car up, I noticed a slow drip from one of the flex lines to the cooler. Tomorrow I will go to the hose shop and get the hoses relined. Driving impression will follow! Flicks if anyone cares! Hola eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 06-30-2009 at 10:22 PM.. |
Hey,
The hose shop hooked me UP! Got the new hoses in and did some idling and oil topping off. Got the oil back onto the middle of the dipstick and took it out for a spin up Hwy 9. Initially I just stayed in the higher gears and throttled it up to generate some heat. Got the tstat to open a about 180F and just started building speed uphill. Temps rose to about 195F when I did my best GTA routine, I was hitting it harder than I normally do, as the speed builds the temps actually start dropping! I stopped at the top to do a leak check and general inspection, all was a ok. At idle for 5 mins temps climbed to 200F, as soon as I took off down hill, still throttling pretty hard the temps dropped to 185F and never rose above that. The only way I can get above 185F, is to go uphill with the skinny pedal close to the floor. I think I am happy, gonna search for a sugar scoop for the marker light position to get a little more directed air to the front of the cooler and call it good. Maybe an electric fan for traffic later on. Hola eric
What temps were you getting before the installation of the oil cooler and what was the air temperature when you tested the new cooler?
winter
I own one too
I'm pretty stoked to see this post on the forum. The PO of my car (PI, with I for Idiot!
) told me he had disconnected the oil cooler. He did, and one my project for the summer is to re-connect it. The cooler on my car ('75 targa) appears to be the exact same model as the one you've acquired, and it sounds as though you're having success with it.I'm going to move this project higher up on my to do list. So far, I've only been driving my car shorter distances, but want to get it out for longer drives and it is starting to get hot here. Thanks for the post and good luck to you, sir! ![]() --- Tom '75 targa |
Hey, Outside air temps were 85F+.
eric
muck-raker
85 degrees is a "cold front" over here.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
eric
Did some baffle work, thought I would collate the oil cooler details: Oil Cooler Baffling! Thanks to all who provided guidance in my quest for cool oil! Hola eric
