| lr172 |
09-03-2009 01:16 PM |
Removing Right Chain Box
I replaced the seals for my left chain box a month ago to rid an upleasant drip. Approximately 2 weeks later, the right right side started to leak. :( The timing was such that you'd think they were related.
The good news is that I am now experienced in chain case removal and cam timing. The bad news is that there is a large hard oil line in the way of the repair.
Can anyone tell me if this oil line can be moved enough once disconnect from the flexible like to get the cover off? The connection at the case seems impossible to remove without first dropping the exchanger and with all of the exhaust stud horror stories I have read, I am not real interested in doing that.
EDIT: This is an '88 Carrera and the oil line I am referring to is the feed from the lower left side of the crankases that snake over to the right side and meets with a flexible line. I believe this is the tube that is replaced with an older style when headers are installed. It passes directly in front of the right chain case.
Thanks in advance for your help.
Larry
