3.2 conversion - engine wont start+fuel from the exhaust
After we finished the 3.2 + g50 conversion the car started on the first starter. but we had a problem with the clutch fork - that made us to drop the engine+gear again .
After fixing the clutch - the engine wont start and fuel is coming out of the exhaust - what should i check ?
I took the computer to electrician and he said the comp. is OK !
Is there any wire or fuse we should check?
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING.
Toyota Hilux 4x4 2000
VW tuareg 2009 3.6
HONDA SH350
Old 09-04-2009, 04:32 AM
charlesbahn's Avatar
Make sure you reconnected the speed and reference sensors to the right connectors and that the ground points- especially the tranny ground strap, are reconnected and tight.
Old 09-04-2009, 07:27 AM
Maybe this will help:
http://www.pelicanparts.com/MotorCity/marcesq1/
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 09-04-2009, 08:50 AM
It did run before which is good and you are getting fuel which is good so you have an ignition issue.
I am not an expert but if you have fuel I suspect the DME relay is ok and you are getting a crank signel.
I would verify it is not getting spark.
I would go over all the electrical touched with the R&R. I might look first at the coil and see if you have juce and are getting a signal there. I would check the coil wire ends to see if they were comprimised. I once lost a coil and the tips of the coil wire were blackened.
Good luck.
Old 09-04-2009, 09:01 AM
