Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
Yah. I just doublechecked. The emissions sticker says that itmeets all EPA and CA emmissions standards for the year 1981.
Damn. For a second i thought maybe I made a bad assumption
Old 09-07-2009, 06:32 PM
deathpunk dan's Avatar
You know I was kidding about the 'all wheel drive scirocco' comment, right?
Sepia brown 1971 911T.
Old 09-07-2009, 06:43 PM
Hehe duh. I thought I'd get yah back with some sweet sweet paranoia.
Old 09-07-2009, 06:47 PM
fred cook's Avatar
More Hp................
Since you have to keep the engine looking like a stock setup, that eliminates the easy choices. How 'bout adding a nitrous oxide setup? If installed carefully you could hide the engine pieces behind the CIS and still get a major "kick" when you wanted it.
Good luck on your project!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Happiest when Tinkering
gsmith660's Avatar
You could go with the Bitz EFI kit http://bitzracing.com/ take a look at the website it can be installed such that it will pass for stock to even the trained eye to a certain extent and the reported hp increase for a 3.0l is 23 hp on the dyno.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 09-07-2009, 06:51 PM
I'm here to cause trouble
jimbauman's Avatar
Strip it! Lose the A/C, all the junk-in-the-trunk, 964 cams (and while you're at it, RSR seals on your rocker shafts just because), cat bypass (except for a week every 2 years), flowmaster muffler (lighter than the stock banana slug). Then for fun, 23/28mm torsion bars, solid engine and tranny mounts, WEVO shifter, strut brace, turbo tie rods, Bilstein sport shocks in the rear, Koni adjustables in the front, harder bushings.... You should be happy with the go-kart like feeling when you're done.
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 09-07-2009, 07:16 PM
Put a cat bypass pipe on it and a sport muffer. Tune it and put it on a dyno to check the Air Fuel Ratios. You can put the cat back on for SMOG time very two years.
SC's with a good suspention, tires, and a little lightening can be extreamly fast on the track. Never going to be much of a drag racer.
Old 09-07-2009, 09:40 PM
