-   -   Testing Andial splitter? (http://forums.pelicanparts.com/porsche-911-technical-forum/496886-testing-andial-splitter.html)
cgarr 09-06-2009 08:00 AM
The old splitters had a switch so you could switch between the lower and upper plugs for testing, mine does not have this switch, what the best way to test? Pull the power wire off one coil? Years ago I just pulled the coil wire to the dizzy and this blew out my splitter.
cgarr 09-07-2009 07:00 AM
Anyone? you twin plug guys? really dont want to fry another unit!
JP911 09-07-2009 06:56 PM
You could do the old school method by pulling a plug wire off a spark plug, attaching a spare spark plug, ground it to the chassis, and have someone crank the motor for a few seconds. You should see a spark. A spare wire makes this easier for testing the lower set of plugs. Good luck!
cgarr 09-08-2009 08:50 AM
I know both sets are firing but I wanted to check each set under a load just to make sure there no coils, wires or plugs breaking down. I called Andial and they said to just unplug the igniter on the unit. I did that and test ran it separate on both uppers and lowers and they were just fine.
efhughes3 12-22-2009 07:17 PM
Craig, how do you like the Andial Splitter? I'm looking at purchasing one.
cgarr 12-23-2009 03:01 AM
I like it, nice clean setup.
efhughes3 12-23-2009 08:53 AM
Thanks. I'm trying to decide whether to use this or an XDi setup for twin plugging. I'm tired of mixing 100/91 octane to keep my SW chip in place, based on its current setup. While the idea of some adjustment appeals to me, I'm probably better off leaving the decision on my tuning to someone such as Steve W, so I don't fry something. It seems the Andial setup is conducive of this.
cgarr 12-23-2009 08:57 AM
Don't forget, you can tick your timing down a few degrees and increase the fuel a bit using the switch on the motronic box.
JP911 12-23-2009 09:59 AM
Going to twin plugs, even with a stock distributor will make the car nearly impossible to register in CA. That aside, a 964/993 distributor with 993 coils and said Andial splitter would be the way to go!
efhughes3 12-23-2009 10:02 AM
My car is already "impossible", in theory, to register. :D
