-   -   1973 911T Engine conversion to 2.8 RSR Engine. Need help. (http://forums.pelicanparts.com/porsche-911-technical-forum/496996-1973-911t-engine-conversion-2-8-rsr-engine-need-help.html)
NavySailor47 09-06-2009 05:30 PM
Hi. I have a 911T from 1973. I am starting my RSR project. I want to convert the engine to an RSR Engine. Where do I start? Is there a book out there based on doing one of these conversions? First of all, the 1973 had a 2.8 Liter Engine. I need to find a company which is well known for doing a good job at engine conversions, and for a lower price than other companies. Not trying to be cheap, but I want the best price. From there, I need a good transmission. What type transmission should I be looking for to have better performance from my 911? Did the RSR have a transmission like the one currently in my car? What can I upgrade to make that a better transmission? Thanks for the help!
Jim Dorociak 09-06-2009 06:10 PM
Bruce Anderson wrote 911 Performance Handbook - there is a 3rd edition just released -- seriously a very good starting point to understand Porsche, Porsche engines, all the different versions and most importantly what you can and can not do. Even if you choose to let someone build for you -- you need knowledge. The 2.8 is one of the most expensive, hard to build, and may not actually be the best choice of a hot rod 911 engine. Jim
NavySailor47 09-06-2009 06:13 PM
TRE Cup 09-06-2009 06:20 PM
i could write pages on the differences between a stock 73 cis T and the 2.8 RSR. You can find a LOT of great information on the early 911S registry site.
No matter what , if you are after an ACCURATE reproduction of the 2.8 RSR motor, this will be a very expensive project !
some sample pricing
new high butterfly injection manifolds, with stacks, linkage (excellent reproduction) $8k from europe New old stock original $14k
rebuilt and modified mfi injection pump , new injectors, mfi lines, $6-8k
donor 2.7 engine (your cis motor is not cost effective to use) $1500
full machine shop services to a 7R case, cylinder heads, crankshaft etc $3k +
twin plug distributor, twin cd units, wires, holders $3000 or so
small diameter RSR alternator ring, small diameter fan blade, correct german twill fiberglass shrouding $3k PLUS another 40 hours to make it all fit
RSR oil filter assy- repro, with block off $2500
RSr camshafts- new aftermarket billets $800
2.8 RSR pistons and cylinders- $4200
RSR replica headers with megaphones- mild steel coated $1000
Misc rebuild items needed in the motor- budget $3k
Labor to "blue print" and assemble, run in $6k
Definitely nose bleed territory !:D
NavySailor47 09-06-2009 06:29 PM
Well I think that I will just try to find another engine to rebuild. How hard is it to bore out the "T" engine to a 3.0?
TRE Cup 09-06-2009 06:56 PM
that won't happen- the case is too small, and the super rare 3 liter andial p/c kit for the 7r case is no longer available
find yourself a decent condition 3.2. it will bolt up to the trans in your car, with just a cut for the sensors in the bell housing. Great motor that delivers a lot of power with a steve wong chip, ssi's and a sport muffler. best bang for the money
Duckworth 09-06-2009 07:23 PM
Quite a few guys want to make the RSR expression to their cars - and one thought might be to just maintain the narrow bodied look of the car....
RSR look cars are certainly nice - but so is an 911R interpretation..... Meaning, what about pitching a few hundred lbs. --- and in keeping with a spartan engine compartment - consider dropping a 2.4 litre that is gone over.
That is a nice combination that wouldn't pin you hard on dollars - and allow you to
sort out the suspension to your satisfaction.
______________
'82 Targa - sold
'77 Spitfire
NavySailor47 09-06-2009 08:40 PM
Well call me crazy, but I have fallen in love with the RSR. It's just so beautiful. I really have nothing better to spend my money on, and what better way then to spend it on something that I have been dreaming of having my whole life.
NavySailor47 09-06-2009 08:42 PM
Can the 3.0 SC Bolt up to the Transmission in my car?
regency 09-06-2009 09:15 PM
NS47, the best advise i can give you is to research everybody / everything. There's a lot of scammers out there waiting for someone like you ( new to Porsche restoration ), and will promise you the world ( engine rebuild ) for cheap.
If i could start over on my project ( 911 resto start 2005 ), and knowing what I know now, I would go to the best builder out there with the best, reputation. Period.
you can go to all the ass holes that say they can do it faster & cheaper and they're all FULL OF *****.
Pay to have a real pro do it right. Or, pay half the price, get a ***** engine that leaks, makes no oil pressure and a million dumb ass excuses from the dumb ass so called builder.
my 2 cents
boba 09-06-2009 09:51 PM
You have gotten some good advice, a '73 RSR is a great car and project, but you should do lots of research and planning befor you start spending your money. Many of the parts are very expensive and hard to source. Dave gave you some ideas on engine parts. There are also transmision, suspension & brakes, body, interior, and wheels and tires. The 9 & 11 x15 Fuchs will run $10K and the tires another $2k.
Look on the engine forum on this board,
www.early911sregistry.org
http://www.pbase.com/slidevalve911rsr
These will give some ideas.
edit to correct link.
kiwiokie 09-07-2009 05:56 AM
Depends whether you want the look of the RSR or to recreate one with a degree of authenticity. From everything I have read on this forum the latter is a very expensive route. There was a nice viper green RSR-look for sale recently so check the for sale forum to see what a good look-a-like might cost to build. I suspect the seller has much more in this car than the sales price. The S/T look is also pretty cool.
Hebrewhomeboy 09-07-2009 07:07 AM
Of the 911 engines, which one is cheapest to modify, in general? Does one trump another, or are they all similarly priced to modify?
Turboo934 09-07-2009 07:25 AM
Find an early 930 and your 80% there.Fifteen years ago it cost 60K to build a RS look car,today it could cost triple that. The Viper Green one is a slamin deal.
unclebilly 09-07-2009 07:57 AM
WORD TO THE WISE... STAY AWAY FROM MOTOR MEISTER
the *inocence* of your initial post lead me to giving this advice.
Why not build a 2.7RS engine? You can do this fairly inexpensively.
RWebb 09-07-2009 08:30 AM
yes - may need some clutch mods
racer_X 09-07-2009 10:05 AM
Hi I am a new 911S owner- I just bought a 1977 with 139k, with a mint interior, good older original color respray, perfect condition Fuchs, and a nice pulling 2.7 for 7K. Everything works on the car including the sun roof, windows and electric antenna. I have the full history including the rebuild at 81k that upgraded the studs to dilavars, the cooling fan to the 11 blade, then at 121k the tensioners were replaced with oil tensioners.
Other than the points closing up on me on the way back from Lime Rock race park this weekend, and using 7 sheets of a 1981 road and track magazine to set the gap- it has been flawless.
The question in my mind with this "unwanted" 2.7 911 is what are the upgrades that will get me to a carrera 2.7 or 911R in power or should I just look for a 3.2 and put the motor on a stand for resale with the car when I am ready to sell? I am interested in maybe doing some track days.
Steve@Rennsport 09-07-2009 10:44 AM
my 2 cents
That is positively stellar advice.
TRE Cup 09-07-2009 07:35 PM
racer_x: go buy a 3.2
Duckworth 09-07-2009 08:19 PM
Originally Posted by NavySailor47 (Post 4881842)
Well call me crazy, but I have fallen in love with the RSR. It's just so beautiful...
I understand what the RSR represents to you... They have a certain charisma all their own. Just raising the possibility of falling out of love with it in favor of something that may return you more enjoyment in the long run.
Navysailor, just shootin' the bull a bit with you. Consider - hoards of 911 enthusiasts are swayed by the flared fenders of an RSR - myself being no exception. Many times I woke up in in bed saying, "I GOT to have an RSR..."
http://forums.pelicanparts.com/suppo...leys/roker.gif
..It took me a good while to evolve out of that mindset. But then I started noticing on Pelican - some of the outstanding early cars like this one :
http://i29.tinypic.com/10p6ddg.jpg
It has some of the 'feel' of an RSR - without all the sheetmetal work required.
Best wishes to you sir !
____________
porschenut 09-07-2009 09:25 PM
If it's the looks you're after, go for it! No reason not to. But remember, the RSR engine is not a street engine - it's a race car and it wasn't designed to last very long between rebuilds. It's just not practical for a street-driven car.
I suggest you lighten up your car as much as possible, put some shorter gear sets in the 915, and hot rod the 2.4 engine you have. Or put in a 3.2 instead, with carbs, S cams, JE pistons and headers.
Dan Morton 09-08-2009 06:46 AM
I have a set of 2.8 RSR mahle Pistons in my 2.0 ('68) mag case courtesy of the PO. I just rebuilt the engine and saw that they bored out 2.7 cylinders, machined down the cyl walls plus machining on the case to make them fit. The crank and heads are still original spec to the 2.0 and the cams were re-ground to be more mild vs. aggressive. The engine has a flat torque curve, pulls great and was dyno'd at 170rwhp. This has easily outrun my buddies '89 carrera and leaves my '70 2.2E in the dust
I'm certain you can find a set of 2.8 RSR pistons without breaking the bank. Not sure what other mods you would need to do but buy Bruce Andersons book as recommended by others.
My '68 was converted to an RSR look by the PO. I like the looks of it but if I were to do it myself I would go with an R or ST look.
-Dan
RWebb 09-08-2009 12:26 PM
the mods & cost est.s were itemized above by an expert
it will be very very spendy
another expert said buy a 3.2L motor - also good advice
chiroracer 09-08-2009 03:04 PM
Anyone mention backdating a turbo? El Burro
NavySailor47 09-08-2009 05:41 PM
I am pretty sure that I am going to go with a 3.2 or a 3.0, whichever seems to be a better buy when the time comes for me to buy an engine. I'll probably rebuild it myself.
There is just something about this car. And I don't mean the looks either. There is just a beauty to it. It is truly a work of art. The sounds, the looks, the thrill of driving it. Everything that this car has is what I am looking for in a classic car, and nothing is stopping me from getting it.
RWebb 09-08-2009 06:14 PM
welcome - I see you have now been assimilated into the Borg...
Lukesportsman 09-08-2009 06:34 PM
Going 3.2 gives you more flexibility and the use of EFI. The 3.0 CIS can be dead reliable, but limit you in cams and compression. Neither will sound like MFI or ITB's or sadly even carbs. A 3.2 would be a good starting point in my opinion as its got great heads, EFI, and more cc's. As your build continues a switch to ITB's (Jenveys or TWM) will get you much of the sound/looks back and make it rev opening up cams and exhaust options.
1. Swap and get it running with 3.2
2. Backdate exhaust
3. Change induction and add cams
This will be cheaper and likely faster in street trim to the high strung 2.8 for much less $. IMHO
NavySailor47 09-09-2009 06:54 PM
What type of exhaust would you recommend with the 3.2? How about with the 3.0? Thanks!
Plavan 09-09-2009 07:02 PM
Save that early narrow car and buy this and cut it up... 73 911T with 2.4L/cage RS Clone- race car. $28k
Shameless plug :)
http://forums.pelicanparts.com/uploa...1252548128.jpg
Shaun @ Tru6 09-09-2009 07:04 PM
I'm going to be a wet blanket here and recommend that you put some money into a 2-day driving school that will make appreciate what your car, and you, can do now. What you will learn over the 2 days will make you a better, faster, slower, more responsible driver. Going fast is rarely about just plugging a bigger motor into your car.
Plavan 09-09-2009 07:07 PM
____________
Right when I was considering making it a 911ST you have to post that with my favorite picture of my car....shame on you :)
YTNUKLR 09-09-2009 11:33 PM
I have built one, and am currently finishing another, 2.8 "Short Stroke" RSR engine with NOS High-butterflies, NOS RSR 2.8 Space cam in the MFI pump, RSR new billet camshafts, RSR forged steel rocker arms and lash caps, special machine work, original Marelli distributor, German twill fiberglass, stainless steel headers, all the cosmetic "fixins". Both of these "RSR Spec" 2.8 MFI engines are based on a 1976 3.0 930 Turbo case (aluminum block, "911SC" head stud spacing, 95mm cylinders, big valves, etc...very much like 3.0/3.2) using a 2.0L/2.2L crankshaft to bring the stroke down to 2807cc, exactly 1 cc less than the original (2808cc 92x70.4 bore/stroke).
Absolutely, bar none, the sexiest thing a vintage Porsche guy could like. The only thing sexier, perhaps, is dropping a 956 2.8L Crankshaft and GT3 Titanium connecting rods into a brand-new 2010 GT3 motor (I envision that it becomes a 3.5L super-short-stroke, ~9500rpm storm in a teacup).
What Dave says is completely spot-on. These are $50-55k motors. There is still more optimization you could do. The clients' goals were a complete original look, spellbinding performance, 8500 rpm redline, and I've imposed a goal of 110hp/L (what the original RSR did--I think we'll "break on through" that).
If you have the money, you've thought about it for a long time, have everything else taken care of, and know in your heart of hearts it is something you cannot be without, there are others in that position who have taken the leap. BUT, if that is not the case, freshen up a Euro 3.2, put in a Steve Wong chip, headers, a pair of supercup 993 cams and a lightweight clutch, and spend the balance on trackdays and having a good time.
my 2 cents.
[Will post dyno sheets as soon as I get this done.] ;)
TR 09-10-2009 01:47 AM
You must only be young
House , Wife, Kids, land rates, electricity, water, gas, phone bills---Not necessarily in that order---------------Porsche.
Good luck with the RSR
Terry
NavySailor47 09-10-2009 03:16 AM
Terry
Military = Free House, No land Rates, Free Electricity, Free Water, Gas is Cheap, No phone bills. And not to mention; I'm not married, nor do I have kids.
You'd be surprised of how well our military takes care of us. I know a Chief Petty Officer who owns four completely restored vintage mustangs, and a Brand new Shelby Mustang. We work for it. And when we're done working, it's great to have things like that to play with. But my Porsche is much more than a toy to me.
Thanks for wishing me good luck. :)
NavySailor47 09-10-2009 03:23 AM
I never stated that I wanted to go faster, but okay. I do plan on going to a driving school the next time I am authorized leave. I do know how to drive pretty well, if I may say so. I'm not the best, and I do have a lot to learn, but I certainly know how to appreciate an automobile. I know when to push it, and when to take things slow. Thanks for the advice.
NavySailor47 09-10-2009 06:16 AM
I'm definitely going with the Euro 3.2 or the 3.0 SC. To spend $50,000 on an engine alone, is illogical. Sure, I have the time and money to build and RSR replica, but I don't have the money to just be rebuilding a engine like that, (from the information that I have been receiving). Thanks for the advice. Keep it coming. I am wanting to learn everything that I can before I start this project.
my 2 cents.
Hebrewhomeboy 09-10-2009 08:20 AM
Is it possible to put a 2.0/2.2 crank in an SC 3.0 engine? And by possible of course I mean will it fit without tons of modification? Seems like if it will fit, you could put the smaller crank in an SC motor, install some bigger cams and webers/JE pistons/SSIs and a good exhaust and have a really fun motor that would be budget friendly. Well, budget friendly from a Porsche perspective.
YTNUKLR 09-10-2009 11:07 AM
hebrewhomeboy-
No, it's not possible with an SC engine block. The 1975-1977 Carrera 3.0 and 930 Turbo (3.0) engines used the aluminum block and 911SC head stud spacing, however, they used a 6-bolt 2.7L crankshaft originally, which has the same stroke as the 3.0 crankshaft. When Porsche made the 911SC engine, they changed the crank to a 9-bolt updated unit, and made corresponding changes to the case. Since the 2.0/2.2L 66mm Short stroke crankshaft from the early engines is a 6-bolt only, it will not work in anything later than a '77 C3.0/930 case or 2.7 case.
There is however, a very rare 956 2.8L crankshaft that Porsche made, that has a 66mm stroke, fits inside all dry-sump engine cases from 1978-2010, and has 911SC rod journals.
GaryR 09-10-2009 11:18 AM
Your first PCA Driver's Education day will quickly show you how little you know about driving a Porsche well, trust me. :D
boba 09-10-2009 11:29 AM
Originally Posted by YTNUKLR (Post 4888879)
hebrewhomeboy-
Scott, I think Henry at Supertech had some cranks made which can be used in the 3.0 SC case that had 66mm stroke. He may still have some.
BTW I agree the 2.8ss is a sweet one.
