-   -   New member hello and 1st big problem! (http://forums.pelicanparts.com/porsche-911-technical-forum/498342-new-member-hello-1st-big-problem.html)
dewshan 09-12-2009 08:16 AM
Hello, I am new to working on Porsches. I am trying to get a 1977 930 running after sitting for many years for a friend. The car has around 60,000 miles on it. I think I have reached my first stumbling block. While replacing the spark plugs I noticed this loose part moving around. fished it out with a magnet. Does anyone know what this is? and the best way to go about fixing it? can it be replaced without removing the engine? http://forums.pelicanparts.com/uploa...1252768582.jpg
JMH82SC 09-12-2009 08:20 AM
Welcome! That is a broken head stud. Do a search and you will find many many pages of info on broken head studs. I just rebuilt my engine because I had 2 broken.
jkh2cpu 09-12-2009 08:31 AM
As JMH said, broken head stud, and yes the engine / transmission needs to come out, and the studs need to be replaced. Also around 60 K, you might want to look at valve guides. The test is if you can move the end of the valve stem side-to-side with a screwdriver you need new guides. Ignoring broken head studs and shot valve guides will escalate the repair costs. With the right tools and and skills, the head studs can be replaced at the kitchen table (joke), but the heads need to be sent out for inspection and repair. You'll need good manuals with specs to tear down and rebuild. Lots of folks here have done it, and will be glad to help on the internet. Throw in some beers, and you may draw locals out of the wood work ;-)
ossiblue 09-12-2009 08:31 AM
Yes, welcome aboard and welcome to the wonderful world of "while I'm in there..." Definitely a broken stud. Could be worse, but you're at your first significant repair. Lots of help here so don't be afraid to ask.
Gogar 09-12-2009 08:32 AM
Yes, Welcome!!!
That is a Porsche specialty tool, "P69: Wallet lightener."
Depending on your skill and your luck, it could mean hundreds or (especially with a 930 engine) thousands. Don't let it bug you though, just search and read and everything will be fine.
viking911 09-12-2009 09:15 AM
Spend enough time on this site and you'll be posting pics of yourself from inside the engine bay before you know it.
Buy both of Wayne's books and let the fun begin.
Welcome.
dewshan 09-12-2009 09:23 AM
Originally Posted by Gogar (Post 4893003)
Yes, Welcome!!!
Hilarious! I was hoping to not need the P69 tool!
Thanks for the help. I think I am about to learn more than I thought I would have to about the car
