New member hello and 1st big problem!
Hello, I am new to working on Porsches. I am trying to get a 1977 930 running after sitting for many years for a friend. The car has around 60,000 miles on it. I think I have reached my first stumbling block. While replacing the spark plugs I noticed this loose part moving around. fished it out with a magnet. Does anyone know what this is? and the best way to go about fixing it? can it be replaced without removing the engine?
Old 09-12-2009, 08:16 AM
Welcome! That is a broken head stud. Do a search and you will find many many pages of info on broken head studs. I just rebuilt my engine because I had 2 broken.
82 911SC
74 MGB
97 Land Rover Discovery
Old 09-12-2009, 08:20 AM
jkh2cpu's Avatar
As JMH said, broken head stud, and yes the engine / transmission needs to come out, and the studs need to be replaced. Also around 60 K, you might want to look at valve guides. The test is if you can move the end of the valve stem side-to-side with a screwdriver you need new guides. Ignoring broken head studs and shot valve guides will escalate the repair costs. With the right tools and and skills, the head studs can be replaced at the kitchen table (joke), but the heads need to be sent out for inspection and repair. You'll need good manuals with specs to tear down and rebuild. Lots of folks here have done it, and will be glad to help on the internet. Throw in some beers, and you may draw locals out of the wood work ;-)
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 09-12-2009, 08:31 AM
Yes, welcome aboard and welcome to the wonderful world of "while I'm in there..." Definitely a broken stud. Could be worse, but you're at your first significant repair. Lots of help here so don't be afraid to ask.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Band.
Yes, Welcome!!!
That is a Porsche specialty tool, "P69: Wallet lightener."
Depending on your skill and your luck, it could mean hundreds or (especially with a 930 engine) thousands. Don't let it bug you though, just search and read and everything will be fine.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 09-12-2009, 08:32 AM
viking911's Avatar
Spend enough time on this site and you'll be posting pics of yourself from inside the engine bay before you know it.
Buy both of Wayne's books and let the fun begin.
Welcome.
1976 911s Targa
Old 09-12-2009, 09:15 AM
Originally Posted by Gogar View Post
Yes, Welcome!!!
Hilarious! I was hoping to not need the P69 tool!
Thanks for the help. I think I am about to learn more than I thought I would have to about the car
Old 09-12-2009, 09:23 AM
