993 calipers striped
In the middle of a restoration and I am installing a set of 993 calipers on a 930. It looks as like the female socket for the brake line is striped. Any pressure causes brake fluid to leak out. Anyone come across this? I thinking of using a bottom tap but I can't find the diameter or pitch? Need help hate to buy another caliper.
Old 09-12-2009, 10:30 AM
Northern Motorhead
wildcat077's Avatar
Should you ever decide to sell your 930 calipers,put me in line first as i want to upgrade my Carrera brakes over the winter...
Thanks!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-12-2009, 10:51 AM
930 brakes
sorry 930 brakes gone
Old 09-12-2009, 07:08 PM
billytan's Avatar
Hi JayH, Sorry am not writing to answer you question but to ask you a few regarding installing 993 calipers on 930. Could 16 inch Fuchs be used still? Rotors need changing? Any modifications needed or bolt on? Many thanks. Billy.
Old 09-13-2009, 05:42 AM
The 993 fit on the 930 with no modification. The rotors are stock. Also the 16" fuchs will fit.
Old 09-13-2009, 06:04 AM
Bill Verburg's Avatar
from memory 10x1.25, I'll check when I get home Mon
Bill Verburg
Old 09-13-2009, 08:49 AM
djpateman's Avatar
All brake lines, and the larger bleed valves are 10 x 1.0
If it is stripped though, you are in trouble; there is probably no material left to engage. A tap would probably make things worse. A 'Time sert' may be a solution. Or welding and tapping.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-13-2009, 03:37 PM
dj is correct 10x1.0
Bill Verburg
Old 09-14-2009, 04:08 AM
