big port heads
Silly question, start the flame thrower
What exactly does "big port heads" mean? Thanks in advance
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
AutoBahned
the air-fuel mix and the burned up waste gases enter and exit the combustion chamber thru the ports
flowing more stuff makes more hp one way to flow more stuff is to make the ports bigger |
Also in the 911 context:
For US market cars the 78-79 911SC had "big port" heads with 39mm intake port. Then Porsche went back to 34mm intake port for 80-83 cars, i.e. "small port". For ROW cars I think they stayed with 39mm port throughout the model run. The general consensus is that the smaller port produced more torque earlier in the RPM range for increased driveability while the larger port favored high RPM output.
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
'76/77 930/02 used in Carrera 3.0 had 39/35mm ports as did the 930/03, 04, 05, 06 used in SCs '78/79 for '80-83 all the SC's, 930/07, 08, 09, 10, 12, 13, 14, 15, 16, 17, 19 used 34/35mm ports then there were the really big ports used in 930/18 3.0 SC/RS @43/43 all of the above used the same valve sizes @ 49/41.5mm
Why did Porsche go back to the smaller ports for '80-83?
Dan Criss ================== 1980 911sc wide body |
Thank you all for the info.
