-   -   Replacing Fuse Block (http://forums.pelicanparts.com/porsche-911-technical-forum/499782-replacing-fuse-block.html)
scoll911 09-17-2009 10:40 PM
Guys,
As I have been having electrical issues, I plan on replacing my fuse box this weekend. Unfortunately, I believe the current wiring was jacked by the PO and I do not time to get a bentley manual.
Cold someone please post pictures for a 78 911 or point me in the direction of good schematics?
A picture of my current box is shown below. As you can see it needs shot and sent to the glue factory.
http://forums.pelicanparts.com/uploa...1253252354.jpg
scoll911 09-19-2009 12:47 PM
Nobody??? You guys love posting pictures
Does somebody have a schematic for the fuse box. I have the old one off and I would like to wire the box back to the stock set-up
kodioneill 09-20-2009 05:45 AM
http://forums.pelicanparts.com/uploa...1253450626.jpg
http://forums.pelicanparts.com/uploa...1253450666.jpg
http://forums.pelicanparts.com/uploa...1253450677.jpg
http://forums.pelicanparts.com/uploa...1253450688.jpg
http://forums.pelicanparts.com/uploa...1253450699.jpg
http://forums.pelicanparts.com/uploa...1253450708.jpg
http://forums.pelicanparts.com/uploa...1253450721.jpg
glennspiegler 09-20-2009 05:59 AM
Let us know how big a job this turns out to be. What are you replacing it with? I have had several fuses which look good, but were the problem and should do the same project. Thank, Glenn
scoll911 09-20-2009 01:30 PM
Thanks for the info guys, I have finished replacing the block. The PO used a a 12 fuse block and totally rewired everything. After replacing witha stock one everything seems to workk correctly --- except my turn signals arn't working.
It seems the two fuses for the turn signals do not have power. I used a test light on both and neither had power (with engine running. Any ideas???
http://forums.pelicanparts.com/uploa...1253478595.jpg
http://forums.pelicanparts.com/uploa...1253478633.jpg
fred cook 09-20-2009 02:37 PM
Fuse Block
Some of the fuse positions have a brass jumper built into the back side of the fuse block. Did you make certain that you have the correct fuse block? On my SC, there are a couple of fuses that have a power jumper wire running from the "top" side of a hot fuse to the "top" side of other fuse postions. If you know which fuses work the turn signals, you probably could just run a power jumper to those locations. On the SC fuse box. there is a red power wire running to the "top" of fuse #11 that (according to the factory wiring schematic) is from the "electronic ignition unit". Also, there is a red jumper wire running from there to the "top" of fuse #16. According to my schematic, fuse #11 is the one for the back up lamp switch and for the turn signal relay. Fuse postions #9 and 10 are associated with the hazard flasher. The fuse numbers are counting from the front of the car towards the back. Hope this will help you some.
